Hi,
We were able to take the sound from our church audio from a Mackie Dl 1608 mixer (analog audio output only, but controlled with an iPad) to a M-Audio 192|8 digital interface to convert the analog to a digital signal with USB C output to OBS. Have also used the USB A port to our computer.. We selected Audio Input Capture as the source and then added M-Audio as the device. In Audio Input Capture, we do have to re-select the M-Audio as the audio device in properties each time we reconnect.
In Windows 10, we also installed the M-Audio 192|8 driver and then went to sound settings in the Control Panel and set M-Audio 192 as the default device for recording and disabled the computer mic as a recording device.
One final note, we are planning to use Dante (over ethernet) using a Dante Via device to take our audio to our network cable and with our planned move to PTZ cameras with PoE+, we hope to have only one ethernet cable to plug into our computer for audio and video. We will see how that works.
The sound for our live streaming is just so much better taking it directly from our audio system as set out above.
Hope that assists.
