Question / Help Roxio GameCap HD Pro Audio Problem
Craig Brown
Hi im extremely new here but I do visit this forum alot for tips and resources OBS has saved my stream from xSplit but now it seems like its almost a better choice for a problem I am having in OBS Studio.
Recently I have been streaming my games through the Xbox App but it keeps tanking so I dusted off the ole Roxio card and hooked it up with studio...but the only problem I am having is my stream can hear the audio but I cant. I went in to the settings of the capture card via OBS studio and clicked properties and came across the audio output mode was set to Capture audio only. the other options were output desktop audio for either directsound or wave out. When I select either one my capture goes blank unless I select a custom audio device (which the only one active under my recording devices is my blue mic). This is literally my only problem i have and then i should be fine.
Im puzzled on how to get my in game sound to work for both my stream and I. Is there a possible work around I can use if this is still in development or something or am I missing something very simple. Any help will be appreciated
