Question / Help Require audio solution for more than one camera input!
Blakey
Hi All,
I'm having a few issues regarding the correct setup for audio for live streaming, hope someone can help me.
With just one camera no problem with audio as sound comes from the camera (sony ex1) via SDI using a 'ultrasonic mini studio' into macbook via thunderbolt and into OBS, all good. But the problem arrises when I want to add a second camera via the same method. So when mixing between the two camera or even mixing between 1 camera and a still image I loose the sound.
1, Is there a way of still have the sound via SDI from camera one without the video showing. (so the sound remains constant even when mixing between camera or anything else, or
2, Do I need a separate sound mixer that I need to plugin my XLR's and if so which one is best as want to keep it small and portable.With this setup will I also have a problem with sync...hence the reason of wanting to keep it with the camera feed.
Hope this makes sense ?
Look forward to any help as it would be much appreciated.
