Recording electrical guitar together with webcam video: guitar sound not loud enough
Olav50829
Good morning everybody,
I'm trying to record a webcam video input together with the sound of my guitar with OBS because I don't want to record the video and the sound seperately and combine the two with a video editing software.
I'm using a logitech C270 webcam, a Focusrite scarlett Solo and Ableton Live 10 lite (other DAWs are also available, e.g Amplitube 5 or Studio One). I also have installed ASIO Link Pro Tool as a driver because this was recommended to reduce latencies in some You Tube tutorials.
I tried to record my guitar sound together with the video input from the webcam many times with different settings as came to my mind using both ASIO Link Pro and the Focusrite driver, but I was not able to get a satisfying result with regards to the sound of the guitar. The sound when playing the recorded video with VLC at 100% volume is very quite of muffled. I watch several OBS tutorials and also studied the FAQ and help files.
When recording the guitar with a DAW the sound of the guitar is very good.
I'm running out of ideas how to set up OBS to get a good video.
I have no idea what I'm doing wrong and I'm getting quite frustrated...
I would really appreciate if someone here could give me some hints what I have to setup to get a better sound.
I have attached the last log file from my latest trial last night for your information.
If you need more information to solve the issue I would be glad to share more details about my setup and settings.
Thank you very much in advance for your help.
Greetings,
Olav
  • 2021-05-18 01-33-02.txt
Olav50829
That's much better!
Thank you very much, Tomasz!
Nevertheless I have to admit that that the volume on the recorded track is not as loud as I expected it to be when the levels are in the yellow range (around -15dBFS). Is that normal?
