Question / Help Question: how to keep microphone settings separate between scenes?
JJAllday
Hello all I just have a minor question. I stream games on my PC and my Nintendo Switch using an Elgato HD capture device and on OBS I created two scenes to separate the two. There is a delay in the video stream using the Elgato so I set my sync offset so that my voice matches with what is happening on the stream. I was just wondering is there a way to keep the sync offset settings separate between my PC streaming scene and Nintendo Switch stream? It is a minor issue but I just do not want to have to open up the settings every time I want to stream my PC or Switch. Any help is appreciated!
