I need some help, my stream quality is really bad even tho I tried every good settings and its still blurry. I think the problem is in my GPU because usage of it is really low when I stream https://prnt.sc/xjsahe. My specs:
i7 9700k
G.Skill 16GB CL15 3200MHz
GIGABYTE gtx 1080Ti
windows 10
Settings in OBS studio:
encoder: NVENCH H.264 (new)
bitrate: 6000
keyframe interval: 2
Rate control: CBR
Preset: Quality/Max quality
profile: high
Look- ahead unchecked
Psycho Visual Tuning checked
base resolution: 1920x1080
video output scaled: 1600x900
downscale filter: lanczos
common fps: 60
Any idea how to fix my GPU so it streams normally, like good quality and stuff. Here you can see my vods how my stream looks like with this settings and I know it should be way better then this: https://www.twitch.tv/naylup
i7 9700k
GIGABYTE gtx 1080Ti
windows 10
bitrate: 6000
Rate control: CBR
profile: high
common fps: 60
