TheCatWithAPlan
So this is what i have for my recording setup :
1920x1080 @ 60fps
NVENC H.264
CBR 50000
B-frames 0
everything else as default like profile and Preset.
the problem:
whenever I'm recording i look to my preview and everything is very delayed and blurry. it never use to do this before. and when i look back at my recording it doesn't look crisp and very high res. idk what has happened but i am in dire need to get this fixed. the videos look very bad.
my log files:
15:59:15.389: CPU Name: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
15:59:15.389: CPU Speed: 3600MHz
15:59:15.390: Physical Cores: 4, Logical Cores: 8
15:59:15.390: Physical Memory: 24524MB Total, 21007MB Free
15:59:15.390: Windows Version: 10.0 Build 14393 (revision: 351; 64-bit)
15:59:15.390: Running as administrator: true
15:59:15.390: Aero is Enabled (Aero is always on for windows 8 and above)
15:59:15.416: OBS 0.16.2 (64bit, windows)
15:59:15.416: ---------------------------------
15:59:15.417: ---------------------------------
15:59:15.417: audio settings reset:
15:59:15.417: samples per sec: 44100
15:59:15.417: speakers: 2
15:59:15.422: ---------------------------------
15:59:15.422: Initializing D3D11..
15:59:15.422: Available Video Adapters:
15:59:15.423: Adapter 1: NVIDIA GeForce GTX 970
15:59:15.423: Dedicated VRAM: 4256104448
15:59:15.423: Shared VRAM: 4268015616
15:59:15.423: output 1: pos={0, 0}, size={1920, 1080}, attached=true
15:59:15.423: output 2: pos={-1920, 0}, size={1920, 1080}, attached=true
15:59:15.426: Loading up D3D11 on adapter NVIDIA GeForce GTX 970 (0)
15:59:15.440: D3D11 loaded sucessfully, feature level used: 45056
15:59:15.873: ---------------------------------
15:59:15.873: video settings reset:
15:59:15.873: base resolution: 1920x1080
15:59:15.873: output resolution: 1920x1080
15:59:15.873: downscale filter: Bicubic
15:59:15.873: fps: 60/1
15:59:15.873: format: NV12
15:59:15.874: ---------------------------------
15:59:15.896: [CoreAudio encoder]: Adding CoreAudio AAC encoder
15:59:15.900: [AMF Encoder] Version 1.3.1.0-1.3.0.5
15:59:15.900: [AMF Encoder] <Plugin::AMD::AMF::AMF> Initializing...
15:59:15.901: [AMF Encoder] <Plugin::AMD::AMF::AMF> Loading of 'amfrt64.dll' failed with error code 126.
15:59:15.936: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
15:59:15.938: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
15:59:15.943: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
15:59:15.948: Failed to load 'en-US' text for module: 'obs-browser.dll'
15:59:15.948: [browser_source: 'Version: 1.25.0']
15:59:15.965: NVENC supported
15:59:16.126: Couldn't find VLC installation, VLC video source disabled
15:59:16.377: No blackmagic support
15:59:16.486: ---------------------------------
15:59:16.486: Loaded Modules:
15:59:16.486: win-wasapi.dll
15:59:16.486: win-mf.dll
15:59:16.486: win-dshow.dll
15:59:16.486: win-decklink.dll
15:59:16.486: win-capture.dll
15:59:16.486: vlc-video.dll
15:59:16.486: text-freetype2.dll
15:59:16.486: rtmp-services.dll
15:59:16.486: obs-x264.dll
15:59:16.486: obs-transitions.dll
15:59:16.486: obs-text.dll
15:59:16.486: obs-qsv11.dll
15:59:16.486: obs-outputs.dll
15:59:16.486: obs-filters.dll
15:59:16.486: obs-ffmpeg.dll
15:59:16.486: obs-browser.dll
15:59:16.486: image-source.dll
15:59:16.486: frontend-tools.dll
15:59:16.486: enc-amf.dll
15:59:16.486: coreaudio-encoder.dll
15:59:16.486: ==== Startup complete ===============================================
15:59:16.513: Service '' not found
15:59:16.514: All scene data cleared
15:59:16.514: ------------------------------------------------
15:59:16.531: WASAPI: Device 'VoiceMeeter Aux Input (VB-Audio VoiceMeeter VAIO)' initialized
15:59:16.544: adding 23 milliseconds of audio buffering, total audio buffering is now 23 milliseconds
15:59:16.545: WASAPI: Device 'VoiceMeeter Output (VB-Audio VoiceMeeter VAIO)' initialized
15:59:16.547: Switched to scene 'Main Game Capture'
15:59:16.548: ------------------------------------------------
15:59:16.548: Loaded scenes:
15:59:16.548: - scene 'Main Game Capture':
15:59:16.548: - source: 'Cap 1' (game_capture)
15:59:17.534: Last log entry repeated for 305 more lines
15:59:17.534: Update check: last known remote version is 0.16.2
15:59:18.249: Last log entry repeated for 227 more lines
15:59:18.249: adding 23 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
15:59:31.053: Last log entry repeated for 4577 more lines
15:59:31.053: rtmp-common.c: [initialize_output] Could not find service ''
15:59:31.096: rtmp-common.c: [initialize_output] Could not find service ''
15:59:32.358: Last log entry repeated for 425 more lines
15:59:32.358: rtmp-common.c: [initialize_output] Could not find service ''
15:59:35.826: Last log entry repeated for 1211 more lines
15:59:35.826: ---------------------------------
15:59:35.826: video settings reset:
15:59:35.826: base resolution: 1920x1080
15:59:35.826: output resolution: 1920x1080
15:59:35.826: downscale filter: Lanczos
15:59:35.826: fps: 60/1
15:59:35.826: format: NV12
15:59:35.834: Settings changed (video)
15:59:35.834: ------------------------------------------------
16:04:49.044: Last log entry repeated for 112721 more lines
16:04:49.044: rtmp-common.c: [initialize_output] Could not find service ''
16:04:49.045: rtmp-common.c: [initialize_output] Could not find service ''
16:04:49.084: rtmp-common.c: [initialize_output] Could not find service ''
16:04:50.743: Last log entry repeated for 563 more lines
16:04:50.743: rtmp-common.c: [initialize_output] Could not find service ''
16:04:52.480: Last log entry repeated for 599 more lines
16:04:52.480: rtmp-common.c: [initialize_output] Could not find service ''
16:10:46.791: Last log entry repeated for 127517 more lines
16:10:46.791: rtmp-common.c: [initialize_output] Could not find service ''
16:10:46.832: rtmp-common.c: [initialize_output] Could not find service ''
16:10:47.531: Last log entry repeated for 221 more lines
16:10:47.531: rtmp-common.c: [initialize_output] Could not find service ''
16:10:53.940: Last log entry repeated for 2273 more lines
16:10:53.940: rtmp-common.c: [initialize_output] Could not find service ''
16:10:55.515: Last log entry repeated for 539 more lines
16:10:55.515: rtmp-common.c: [initialize_output] Could not find service ''
16:10:55.925: Last log entry repeated for 113 more lines
16:10:55.925: rtmp-common.c: [initialize_output] Could not find service ''
16:10:56.469: Last log entry repeated for 167 more lines
16:10:56.469: rtmp-common.c: [initialize_output] Could not find service ''
16:10:56.997: Last log entry repeated for 161 more lines
16:10:56.997: rtmp-common.c: [initialize_output] Could not find service ''
16:10:57.737: Last log entry repeated for 233 more lines
16:10:57.737: rtmp-common.c: [initialize_output] Could not find service ''
16:10:58.431: Last log entry repeated for 221 more lines
16:10:58.431: rtmp-common.c: [initialize_output] Could not find service ''
16:11:05.830: Last log entry repeated for 2633 more lines
16:11:05.830: rtmp-common.c: [initialize_output] Could not find service ''
16:11:05.870: rtmp-common.c: [initialize_output] Could not find service ''
sorry if duplicates
1920x1080 @ 60fps
NVENC H.264
CBR 50000
B-frames 0
the problem:
my log files:
sorry if duplicates
