Python script & LibVLC: Music inside OBS with current title and position
Suk0m8u
Hello, dear community.
Currently i need inside OBS an simple text field with the current playing title and current position of my background music from YouTube.
So i decided to write an simple test script and that works:
Python:
#!/usr/bin/env python3
from time import sleep
from datetime import timedelta
from random import shuffle
from vlc import Instance as vlcInstance, MediaList, MediaListPlayer, EventType, State
class MusicPlayer:
    def __init__(self, mrls):
        self.prepare()
        self.load(mrls)
    def prepare(self):
        self.player = MediaListPlayer(vlcInstance("--no-ts-trust-pcr", "--ts-seek-percent", "--no-video", "-q"))
        eventManager = self.player.event_manager()
        eventManager.event_attach(EventType.MediaListPlayerNextItemSet, self.updateTitle)
    def load(self, mrls):
        shuffle(mrls)
        self.player.set_media_list(MediaList(mrls))
    def play(self):
        self.player.play()
        while self.player.get_state() != State.Ended:
            self.updatePosition()
            sleep(0.5)
    def updateTitle(self, event):
        media = self.player.get_media_player().get_media()
        if media.get_meta(1) != None:
            print(media.get_meta(0))
    def updatePosition(self):
        currentPosition = str(timedelta(seconds=self.player.get_media_player().get_time() / 1000, microseconds=0)).split(".")[0]
        print(currentPosition)
mrls = [
    "https://www.youtube.com/watch?v=WEcPAs9gC70",
    "https://www.youtube.com/watch?v=EJTZms5PFg8"]
musicPlayer = MusicPlayer(mrls)
musicPlayer.play()
Okay, now i try to rewrite it step by step for usage inside OBS but even if i uncomment line 16, then OBS closes itself with the message "Segmentation fault".
So what's my mistake?
Python:
import obspython as obs
class MusicPlayer:
        print("NEW")
        self.prepare()
        #self.load(mrls)
    def prepare(self):
        print("test")
        #eventManager = self.player.event_manager()
        #eventManager.event_attach(EventType.MediaListPlayerNextItemSet, self.updateTitle)
        shuffle(mrls)
    def play(self):
        self.player.play()
            sleep(0.5)
    def test(self):
        print("OK")
mrls = [
def add_pressed(props, prop):
    musicPlayer.test()
# Script description
def script_description():
    return "Simple music player"
# Configuration dialog
def script_properties():
    ui = obs.obs_properties_create()
    obs.obs_properties_add_button(ui, "button", "Change text source", add_pressed)
    obs.obs_properties_add_text(ui, "playlist", "Playlist", obs.OBS_TEXT_MULTILINE)
    return ui
Thanks, very much for your help!
Suk0m8u
Okay, on Windows 10 + Python 3.6.8 it works but not with Python 3.9.
On Linux it doesn't work with Python 3.9.3 but there is no 'Python settings' tab.
So how can i switch the Python version for OBS on Linux?
Suk0m8u
Okay, sometimes i am just stupid.
Also don't need threads for my case.
So this topic is solved for me.
How can i close it?
