Yuhg
At first i thought it was my microphone, but it wasn't (i use my mic for singing too). For some reason, it is like my microphone has way less bitrate than it should. But i checked it out and the bitrates were normal. I tried streamlabs obs just to make sure it wasn't my fault configuring something. I imported my settings from OBS to SLOBS, and to my surprise, i can hear myself so much clearer in SLOBS, did some recordings to test and it all comes down to normal OBS. here's a clip on how i hear myself in normal OBS
https://clips.twitch.tv/TiredInquisitiveThymeTTours
and here's a vid on how i hear myself using streamlabs obs: https://youtu.be/gpndrLf3qHs
as you can hear, the difference is abysmal, and both have the exact same configuration. Any ideas?
log file: https://obsproject.com/logs/b7xEsNPFbsYI2otB
