Question / Help Problems regarding audio
Draxvid
Hi, I'm new on the forum. I've been having an issue lately with the recording method using OBS studio, where I followed JackFrags' guide on using OBS to split multiple audio tracks for better recording quality and management for editing. Basically, I followed every step in his guide, and the software records the game perfectly fine, but then comes the audio issue; I have a Logitech G430 headset and a Blue Snowball microphone connected, and both devices work, I use them every day when I'm either playing games or recording some commentaries or something like that for making videos. So then I launch a game (I use the CSGO main menu screen with the inventory and opening cases etc) and OBS picks up and records my microphone correctly. I can even see in the preview screen on OBS that the audio meter from the game is reflecting the sound from it, but when I stop recording and drag the file into Premiere Pro CS6, only one audio track appears, which is my microphone. Both my microphone and headset are selected as the default devices in Windows, so in theory it should work, but it just doesn't.Are there any ways to fix it? It's extremely frustrating because I need it to work. ANy help at all would be greatly appreciated. Thanks!
Simes
You will probably need to extract the additional audio tracks using something else (e.g. ffmpeg), then import them into Premiere along with the video.
Simes
What are you using to check your recordings with? Recommend using VLC and checking each audio track with that.
