tako_games
Hello guys I m gonna try to keep it simple and straight to the point .
As i said in the title I had this problem for the last 2 weeks, while streaming normally the bitrate goes to 300Kbps and then back to normal. It doesnt happen at specific time might happen once every hour or 5 times in 10 mins and it causes the stream to freeze for few seconds but the sound can be heard normally.
I have tried a lot of thinks from this link https://obsproject.com/forum/threads/dropped-frames-disconnecting-lag-read-this-first.8870/ and i eventually called my ISP and they found out the my router is not synchronizing at the same speed the see so they gave me a new one and now it says i m synchronizing at 50 mbps down 5mbps up (actual numbers are around 40-45 mbps down and 4-4.5 mbps up).
I need someone to tell me if possible from my latest log if it is my ISP or my setup so here is the latest log https://obsproject.com/logs/yc1k08JajoVjJF4D .
I can provide a short clip to show you what is happening exactly but i assume you dont need so just ask me if needed.
Specs i7 9700k
Gtx 1060 3gb
16 GB ddr4 3200 mhz
P.S : Just swapped from SLOBS to OBS studio and i think i got everything fine apart the sound is there a special setting i can increase for better mic quality? I ve fixed my filters and i have Sample rate at 48Khz and channels stereo is there any other setting that is recommended for maximum sound quality?
thanks in advance
Specs i7 9700k
Gtx 1060 3gb
16 GB ddr4 3200 mhz
thanks in advance
