PolakPL2002
Hi, I have pretty weird issue. The sound that is played on stream and recording is really chopped like it's dropping samples, but on audio monitor it's not that bad (still every other second it sounds like sample dropping, but not constantly like on the output). There was 0.0% of render dropped frames and 0.1% of encoder dropped frames (during 1.5h stream/recording). I stopped streaming after 20 minutes, but continued recording for another 70 minutes, but nothing has changed. The usual sound route was:
Sample (from around 4 seconds mark) https://youtu.be/CfuLCEV6Bzc
Log: https://obsproject.com/logs/ZenxhPrlcjt6btQC (LGX2-1 audio is not used)
X32 (digital mixer, via USB to PC (ASIO input plugin)) -> VST plugin (disabled for troubleshooting) -> output and monitor
. The weirdest thing about it is that it starts about 10 minutes after start of stream/recording and affects actual output much more than monitor. It didn't happen before sunday. CPU usage ~60%. It happened again on monday after complete system reboot. Is it common issue or something specific?Sample (from around 4 seconds mark) https://youtu.be/CfuLCEV6Bzc
