Question / Help Problem with Sound Imac
Marck
Hello guys I will try to explain it the best I can!
I stream on an Imac World of Warcraft I have downloaded soundflowers to capture desktop sound, and it works fine. My Problem is when I use a second platform like discord/TS/ or battlenet, my stream can't hear my teammates. When I changed the Audio device in Battlenet to soundflower (2ch) my stream can hear my teammates but I can't how come?
OBS does not do audio pass-through. If you want to send audio from a chat program like Discord to OBS so the stream can hear them, you need another program to forward audio from that virtual port to a hardware device so you can hear it.
You can use MIDI setup to create an aggregate output device that includes the virtual device you are streaming, plus a hardware device you are monitoring with.
You can also use the free program LineIn to forward audio from soundflower to your headphones.
https://rogueamoeba.com/legacy/
Scroll to the bottom.
Their commercial program LoopBack also does everything that LineIn and Soundflower do, and more.
https://www.rogueamoeba.com/loopback/
