Problem with scene changing with loss of focus
Jimsw
I just used OBS for the first times and configured with 4 scenes 0900 1000 1100 1200. Each scene runs a different video.
OBS is scheduled to run on the hour, with the appropriate scene at those 4 times
Everything works as expected when a run the task manually.
But after I run 1100 task, from the Scheduler, the OBS has focus, Then when I change the focus from OBS by clicking anywhere else on the desktop, the scene changes to the 0900 scene and starts playing the 0900 video.
Obviously I do not understand what OBS might be doing and therefore am unable to debug this issue.
Please could someone help me to debug this?
I have a second problem, but will tackle that after this is solved
Thanks for any help/suggestions
Jim
Found the cause of the problem. In the Automatic Scene Switcher Tool settings, there was an entry in the setting "When no window matches:" It was set to switch to the 0900 video. !!!! After changing to "Don't switch" the issue was resolved.
