Question / Help Problem with OBS Studio and Avermedia Live Lite HD(C985)
DerikTI
Hey Guys, i want to stream another Console Game on my Channel only Problem is, my Capture Card doesnt seem to work with OBS Studio.
Im using a PS TV with a native Screen Resolution of 1280x720, so i change the Resolution in OBS Studio to that one, but i only get a transparent red Border with nothing in it. If i make the same Changes in the normal OBS it works fine, but i dont want to revert back to the old Program.
If you need any extra Info, please ask but i dont really know which extra Info you could need as you cant really change anything in the Options except the Resolution, which is important because pstv will not give any Video until it is changed to 1280x720.
I don't actually understand what you have done here. Are you using your PS TV to stream from your PS4 and connecting the PS TV directly into the Avermedia? Can you post a screen shot of the properties for your Video Capture Device, here's mine as an example:
Can you also please post a log file details are here:
https://obsproject.com/forum/threads/please-post-a-log-with-your-issue-heres-how.23074/
