Can you explain what the audio bitrate does?@carlcann It all depends on how great is your internet connection,CPU and "bla-bla".You can try using the estimator.
But personally,I use these settings:
Output
Video bitrate:2200(It's best at 2000-2200 for 720p)
Audio bitrate:128
Enable Advanced Encoder Settings(enabled automatically when using Advanced Mode)
Encoder/CPU preset=ultrafast(you can use superfast or veryfast if your CPU can handle it)
Video
Base(Canvas) resolution:1280x720(if you have a monitor bigger than this,use 1920x1080)
Output(Scaled/downscale) resolution:1280x720(720p output,change this to 1920x1080 for 1080p output)
Downscale filter:Bilinear(I use this because I didn't change the Output resolution earlier)
Common FPS values:30(Use 60 if your CPU can handle it)
It determines the quality of your audio.More higher is better.128 is moderate,because when streaming,total bitrate consists of video bitrate+audio bitrate(because you send video and audio together).So if I stream using the bitrate i set earlier in this post,the total bitrate send would be 2328,which is below 2500,the recommended maximum bitrate Twitch non-partnered users should use.
Hope this helps!^_^
Thank you!It determines the quality of your audio.More higher is better.128 is moderate,because when streaming,total bitrate consists of video bitrate+audio bitrate(because you send video and audio together).So if I stream using the bitrate i set earlier in this post,the total bitrate send would be 2328,which is below 2500,the recommended maximum bitrate Twitch non-partnered users should use.
Hope this helps!^_^
