Question / Help Problem with changing settings for different scenes
Hi,
I am using a 4k monitor with 4096 X 2180 settings when I stream Poker, but when I stream video games I use a different setting of 1920 X1080.
The problem is that when I change the settings to stream video games my poker settings are thus affected and then I cannot stream the poker tables with ease like i did with my old 4096 X 2180 settings.
Is there a way where I can keep my settings for the 2 scenes without deviating from the original settings I set up for Poker?
Sapiens
Forum Moderator
Create separate scene collections, not just separate scenes. Keep in mind that you won't be able to switch things like the resolution or frame rate on the fly while live.
thanks for the tip, is there a way i cancreate 2 different profiles which would have different scene settings? The moment Ichange it from the 4k to the 1080 p, every other scene is affected including the edit transform on the scenes from the display capture that I use for poker.
Sapiens
Forum Moderator
That's why you make separate scene collections, not just separate scenes. Use the scene collection menu at the top of the program.
Hi, literally the same problem, I still have to change the settings when i toggle through the scene collections I made. How can I not have to do this every time I want to stream?
