Question / Help Problem Whit OW/FN Low FPS
jimber
Hello everyone, I'm having problems when I want to stream for Overwatch and Fornite, because when I'm about to start the stream the obs indicates that it's running at 30fps or less and starts to go down and up constantly, my settings are at 60fps 1080p, when game lol everything is perfect.
I do not understand what the problem would be and already try everything, my PC has the following feature
Ryzen 1700, gtx 1060 6gb, 16 ram @ 3000mhz, internet 100 / 50mb
Would someone know how I could configure my obs, or if it is Windows 10 or obs? :(
i need a answer, i see molst of ppl whit the same rig and they can stream that, can you help me?, and then how i can stream FN?, when i take out de webcam is 60 fps normaly :S
Well, what I did was to lower the EPIC graphics to HIGH a bit and the obs began to work as usual, NORMAL, and then I went back up the graphics for both Overwatch and fornite, and obs normally takes the FPS to 60 .. ....... I did not understand what happened, but I think this is a resumption for now.
now I was a little worried about what they tell me in the above replica, that my GPU has a big load ... what should I do?
Suggestions:
1) Reduce the size of your webcam capture from full HD 1920x1080 to something way smaller. You rarely use your camera sensor to capture at full HD so its a waste to have OBS process all that data. Change it to something smaller that is 16:9 aspect ratio like 640x360. That will reduce by 66% and reduce CPU and GPU use a little.
2) Your 1060 3GB is just an ok 1080p GPU. I know because I have an older one I no longer use. Don't expect miracles with that card. Its good for general games but something like Overwatch and Fortnite its probably not suited without turning game settings down to the lower settings. For example if you see 99% GPU usage playing Fortnite, you need to turn down Shadows, for example, to Low. Pretty much everything while you are streaming should be set to Low/Medium.
Suggestions:
Thanks Man, i will take the suggestiions
