Problem trying to get OBS to work
Fraval
Hi having a problem trying to get OBS working.It comes up with loads of screens have tried deleting the programme and reinstalling a few times but i cant get rid of these screens, they come back, sure they should'nt be there, but keep coming back on when i reinstall programme. grateful of any help.
Pic of what I keep getting with screens
I did get 1 reply on this but never worked
Reply was
Did'nt work, when I go on display capture it shows loads of screens have tried deleting the programme and reinstalling a few times but i cant get rid of these screens, they come back, but keep coming back on when i reinstall programme. Ive tried deleteing OBS with Revo Uninstaller and removing everything in OBS and reinstalling, but still get nothing in the display screen[only the screens]. Pic here of what I see on PC..Would be very grateful of any helpn [not PC techy at all]
D
Deleted member 121471
What you're seeing is called the Hall of Mirrors effect and @Banyarola already offered the solution twice.
There's no simpler way to put it and you're on your own if you can't follow such a simple instruction.
Banyarola
Have tried to explain I am not PC techy at all,
So could someone please try and explain what I should put in the Source list to get me started
Regards
fraval
Take a look at this....It will help you a lot...
Fraval
Thanks Banyarola, will have a look later, dont think it will do much good as I'm useless with pc. Seems a very complicated programme to set up.
Thanks again
Fraval
