Question / Help Problem installing OBS as 32-bit on 64-bit OS
Fred Branham
Has anyone been able to install OBS as a 32-bit app into a 64-bit Win OS? I can't get OBS to see an HD60 Pro that is installed, tested & working otherwise. I dont see any installation switches that would apply and the instructions are vague...basically appear to match whatever the OS is...which won't work for me. (for studio, not classic)
Harold
if you're using the full installer, it automatically installs both 32-bit and 64-bit.
Check the start menu.
Paulo Silva
Hi
i´m trying to install OBS 19.0.2 at windows 8.1 SL 64bits
i´m using the full installer, and the same errors occours.
and don´t appears the option to choose 32 ou 64 bits in the main menu.
can you help-me ou send me the URL of the 32 bits version, it was ok until i done the upgrad to 19.0.2 (i was using 32 bits installed)
i´m with difficulty to find de 32 bits version into the site to download.
wallrik
There is no 32- or 64-bit installer. There is only a 32-bit installer that installs both versions. The desktop shortcut will default to 64-bit on a 64-bit system.
If you're having trouble finding the shortcuts in the start menu you can just create a new one:
C:\Program Files (x86)\obs-studio\bin\32bit\obs32.exe
C:\Program Files (x86)\obs-studio\bin\64bit\obs64.exe
