Problem for streaming Overwatch, please help me ;( !
Uzumakeur
Hello, everyone!
A short time ago, I started to stream (mainly switch games but also a bit of pc), and being a good Overwatch player I naturally wanted stream the game. Two months ago, I had no problems streaming the game, I could do 2 or 3 streams without any problems.
Except I recently wanted to resume the Overwatch streams, but now IMPOSSIBLE to stream, on my side it’s good but the record is awful (as evidenced by the beginning of this VOD https://www.twitch.tv/videos/790126869?filter=all&sort=time ), and I can not know why.
My setup has remained unchanged since the first stream, hence my incomprehension. Meanwhile, I just changed my crappy second screen against a 144hz screen.
Of course, I tried to lower the graphics parameters and optimize my streamlabs parameters, but nothing helps.
I noticed that my GPU was between 90 and 100% usage when I set a record (that’s the cause, you might say), but then I don’t understand why it worked before with the same components.
Can the fact of having changed the screen be the cause? Bad Streamlabs settings? OW version? If anyone has an answer to my problem, he would be blessed by the gods...
Thank you in advance to those who will take the time to answer me!
My setup :
-Gigabyte GeForce RTX 2060 WindForce OC 6gb
-Ryzen 7 2700 8 cores 3.20Ghz
-16 gb RAM
-Screen 1 : hp 25mx / Screen 2 : Samsung SD330
Uzumakeur
logfile please ! make a little stream and send the logfile
little tip change the display refreshrate to 120 sound stupid but look when he grab the picture he can easy grab very second picture
Sorry, stupid question but.. how do I get the logfile in streamlabs ?
And for the display refreshrate, do you want me to reduce it in my nvidia settings or in my game settings ?
Uzumakeur
you use streamlabs OBS ! here we only Support OBS Studio please send the question to Streamlabs. sorry !
but what i can say bring windows to the newest version and set the refresh rate in the windows displaysettings to 120hz.
and use the REAL OBS STUDIO ;)
Okkkk I though you were able to help me with SL too, my bad... So I'll strat to use OBS, and if I get troubles again I'll come back ask for some help !
Thanks for the advices !
Uzumakeur
Hello back ! So I set up OBS, put my display on 120hz.. And same problem ! Here is the log of the test I made, hope it will help
  • 2020-11-25 17-33-14.txt
Uzumakeur
Up ?
