Question / Help Problem- bsod with two logitech pro hd c920
H4llstorm
Hello, I have a problem when trying to use 2 cameras of the same model (logitech pro hd c920), when I open obs with both connected, a bsod appears and if it does not, when trying to configure the 2nd camera, the configuration applies to the first one. Im using OBS Studio.
Any idea what it could be?
log: http://pastebin.com/GR15Bzfv
Logitech software and drivers will only control one camera.
I had the same problem.. I had to get a second cam from Microsoft and now I have no problem controlling each cam individually.
Update: the registry hack did nothing, so my solution was to disable driver updates in Windows, remove all webcams and delete all drivers (make sure you check "Delete driver files"). Then reconnect everything but don't update the stock webcam drivers in device manager. Seems to work so far, although you lose camera panning, etc.
