Question / Help Poor Audio Quality when recording while using speakers vs. headphones
Earthandspace
I've been having this issue when recording where, depending if my headphones are in use or my speakers, causes a major difference in quality. If I use my headphones to listen to in-program audio, the audio comes out crystal clear and is perfectly fine. However, if I use my speakers to listen to audio, the audio is recorded with a tinny-quality, nowhere near as nice as if I was recording while using my headphones. I put the log in quotes, in the session I did two recordings, the first one where I recorded while using the audio jack (thus the audio is saved w/o any noticeable loss in quality) and the second where my speakers were used (w/ the audio being recorded with much lower quality).
Here is the recording I got with my headphones being plugged in: https://youtu.be/4mqKauU9N1c
And here is while using the speakers, without my headphones: https://youtu.be/BN8gnKahc50
If you need any more examples, please let me know.
10:00:26.703: CPU Name: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
10:00:26.703: CPU Speed: 2808MHz
10:00:26.703: Physical Cores: 4, Logical Cores: 8
10:00:26.703: Physical Memory: 16244MB Total, 11454MB Free
10:00:26.703: Windows Version: 10.0 Build 17134 (revision: 471; 64-bit)
10:00:26.703: Running as administrator: false
10:00:26.703: Aero is Enabled (Aero is always on for windows 8 and above)
10:00:26.703: Windows 10 Gaming Features:
10:00:26.703: Game Bar: On
10:00:26.703: Game DVR: On
10:00:26.703: Game DVR Background Recording: Off
10:00:26.705: Sec. Software Status:
10:00:26.707: Windows Defender Antivirus: enabled (AV)
10:00:26.707: Windows Firewall: enabled (FW)
10:00:26.707: Windows Defender Antivirus: enabled (ASW)
10:00:26.708: Browser Hardware Acceleration: true
10:00:26.708: Portable mode: false
10:00:26.822: OBS 22.0.2 (64-bit, windows)
10:00:26.822: ---------------------------------
10:00:26.835: ---------------------------------
10:00:26.835: audio settings reset:
10:00:26.835: samples per sec: 48000
10:00:26.835: speakers: 2
10:00:27.026: ---------------------------------
10:00:27.026: Initializing D3D11...
10:00:27.026: Available Video Adapters:
10:00:27.043: Adapter 1: NVIDIA GeForce GTX 1060
10:00:27.043: Dedicated VRAM: 2051014656
10:00:27.043: Shared VRAM: 4221650944
10:00:27.043: output 1: pos={0, 0}, size={1920, 1080}, attached=true
10:00:27.043: Adapter 2: Intel(R) HD Graphics 630
10:00:27.043: Dedicated VRAM: 134217728
10:00:27.344: Loading up D3D11 on adapter NVIDIA GeForce GTX 1060 (0)
10:00:27.451: D3D11 loaded successfully, feature level used: 45056
10:00:28.228: ---------------------------------
10:00:28.228: video settings reset:
10:00:28.228: base resolution: 1920x1080
10:00:28.228: output resolution: 1920x1080
10:00:28.228: downscale filter: Bicubic
10:00:28.228: fps: 60/1
10:00:28.228: format: NV12
10:00:28.228: YUV mode: 601/Partial
10:00:28.230: Audio monitoring device:
10:00:28.230: name: Default
10:00:28.230: id: default
10:00:28.230: ---------------------------------
10:00:28.269: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
10:00:28.498: [AMF] AMF Test failed due to one or more errors.
10:00:28.498: Failed to initialize module 'enc-amf.dll'
10:00:29.018: NVENC supported
10:00:29.637: VLC found, VLC video source enabled
10:00:29.710: No blackmagic support
10:00:29.944: ---------------------------------
10:00:29.944: Loaded Modules:
10:00:29.944: win-wasapi.dll
10:00:29.944: win-mf.dll
10:00:29.944: win-dshow.dll
10:00:29.944: win-decklink.dll
10:00:29.944: win-capture.dll
10:00:29.944: vlc-video.dll
10:00:29.944: text-freetype2.dll
10:00:29.944: rtmp-services.dll
10:00:29.944: obs-x264.dll
10:00:29.944: obs-vst.dll
10:00:29.944: obs-transitions.dll
10:00:29.944: obs-text.dll
10:00:29.944: obs-qsv11.dll
10:00:29.944: obs-outputs.dll
10:00:29.944: obs-filters.dll
10:00:29.944: obs-ffmpeg.dll
10:00:29.944: image-source.dll
10:00:29.944: frontend-tools.dll
10:00:29.944: enc-amf.dll
10:00:29.944: coreaudio-encoder.dll
10:00:29.944: LoadLibrary failed for 'obs-browser': The specified module could not be found.
10:00:29.944: (126)
10:00:29.944: ==== Startup complete ===============================================
10:00:29.945: Service '' not found
10:00:29.955: All scene data cleared
10:00:29.955: ------------------------------------------------
10:00:30.010: WASAPI: Device 'Speakers (Realtek High Definition Audio)' initialized
10:00:30.010: [window-capture: 'Window Capture'] update settings:
10:00:30.010: executable: KSP_x64.exe
10:00:30.011: Switched to scene 'Scene 1'
10:00:30.011: ------------------------------------------------
10:00:30.011: Loaded scenes:
10:00:30.011: - scene 'Scene 1':
10:00:30.011: - source: 'Window Capture' (window_capture)
10:00:30.436: adding 405 milliseconds of audio buffering, total audio buffering is now 405 milliseconds
10:02:33.997: [window-capture: 'Window Capture'] update settings:
10:02:33.997: executable: KSP_x64.exe
10:02:47.062: Starting recording due to hotkey
10:02:47.373: ---------------------------------
10:02:47.374: [NVENC encoder: 'simple_h264_recording'] settings:
10:02:47.374: rate_control: CQP
10:02:47.374: bitrate: 0
10:02:47.374: cqp: 16
10:02:47.374: keyint: 250
10:02:47.374: preset: hq
10:02:47.374: profile: high
10:02:47.374: level: auto
10:02:47.374: width: 1920
10:02:47.374: height: 1080
10:02:47.374: 2-pass: true
10:02:47.374: b-frames: 2
10:02:47.374: GPU: 0
10:02:47.374:
10:02:47.830: ---------------------------------
10:02:47.831: [FFmpeg aac encoder: 'simple_aac_recording'] bitrate: 128, channels: 2, channel_layout: 3
10:02:47.831:
10:02:47.886: ==== Recording Start ===============================================
10:02:47.886: [ffmpeg muxer: 'simple_file_output'] Writing file 'C:/Users/user/Videos/OBS Captures/2018-12-16 10-02-47.mkv'...
10:02:53.080: Stopping recording due to hotkey
10:02:53.607: [ffmpeg muxer: 'simple_file_output'] Output of file 'C:/Users/user/Videos/OBS Captures/2018-12-16 10-02-47.mkv' stopped
10:02:53.607: Output 'simple_file_output': stopping
10:02:53.607: Output 'simple_file_output': Total frames output: 313
10:02:53.607: Output 'simple_file_output': Total drawn frames: 343
10:02:53.608: ==== Recording Stop ================================================
10:03:49.334: Starting recording due to hotkey
10:03:49.337: ---------------------------------
10:03:49.337: [NVENC encoder: 'simple_h264_recording'] settings:
10:03:49.337: rate_control: CQP
10:03:49.337: bitrate: 0
10:03:49.337: cqp: 16
10:03:49.337: keyint: 250
10:03:49.337: preset: hq
10:03:49.337: profile: high
10:03:49.337: level: auto
10:03:49.337: width: 1920
10:03:49.337: height: 1080
10:03:49.337: 2-pass: true
10:03:49.337: b-frames: 2
10:03:49.337: GPU: 0
10:03:49.337:
10:03:49.591: ---------------------------------
10:03:49.592: [FFmpeg aac encoder: 'simple_aac_recording'] bitrate: 128, channels: 2, channel_layout: 3
10:03:49.592:
10:03:49.608: ==== Recording Start ===============================================
10:03:49.608: [ffmpeg muxer: 'simple_file_output'] Writing file 'C:/Users/user/Videos/OBS Captures/2018-12-16 10-03-49.mkv'...
10:03:55.734: Stopping recording due to hotkey
10:03:56.254: [ffmpeg muxer: 'simple_file_output'] Output of file 'C:/Users/user/Videos/OBS Captures/2018-12-16 10-03-49.mkv' stopped
10:03:56.254: Output 'simple_file_output': stopping
10:03:56.254: Output 'simple_file_output': Total frames output: 369
10:03:56.254: Output 'simple_file_output': Total drawn frames: 399
10:03:56.255: ==== Recording Stop ================================================
