Resource icon
Play Sound on Save Replay Buffer (+ Edit Sound Effect Volume) 1.0
cwypt
cwypt submitted a new resource:
Play Sound on Save Replay Buffer (+ Edit Sound Effect Volume) - A sound of your choosing will play when you Save Replay Buffer.
1. Choose a .wav file that you want for the notification sound, and make sure to cut it to just the short notification sound. I'll provide the one I use below.
2. While in OBS, go to Tools --> Scripts and add the Lua script provided.
3. Open the Lua file in ANY text editor. Edit AUDIO_FILE (just the part in quotations) to the name (including .wav) of the file you want as your Save Replay Buffer Notification. Then, edit AUDIO_VOLUME to your preferred volume (between 0.1 - 1.0). Save the Lua...
Read more about this resource...
Stoonk!
I have tried so many "sound effect on replay buffer save" scripts but none of them have ever worked. I have no idea what I'm doing wrong I followed these instructions exactly.
Suslik V
@Stoonk! All these scripts supports only ASCII characters from English alphabet for the file path (no Unicode symbols) and works only for Windows.
