Question / Help Output Audio (Works in classic not Studio)
DraB
velvitonator
Does your recording device (you mention console, so I assume you're using an Elgato or the like) show up under the Recording Devices tab of the Sound panel (Right-click speaker in the system tray > Recording Devices)?
If so, you can right-click it and go to the listen tab, and forward that device to your headphones through Windows natively.
-Vitor
DraB
@velvitonator Nope using an Avermedia. Does not show up in recording devices.... Basically I have tried everything. In OBS Studio there is an option to output audio to desktop which works but the stream wont be able to hear the consoles audio.
