Question / Help Oneplus wireless bullets 2 sound problems
VegaDesign
Hi all!
I have some problems with the Bluetooth headphones - my new "Oneplus wireless bullets 2". I using the OBS app to record my meetings via Slack or Google Meet. Also, I use an equalizer app to tweak my sound - EqMac
Here are my settings:
1. I installed the "iShowU Audio Capture" for mac, created some new virtual device "For Record Meetings" and assign "iShowU Audio Capture" to it:
("Oneplus wireless bullets 2" is inactive because I disconnect it for using my "USB Sennheiser headphones" for working, but in general I did the same)
2. In the "EqMac" I have selected my virtual device "For Record Meetings":
3. In the "OBS" sources, I have added the "System Audio" and selected the "EqMac", so the sound from the system works:
4. In the "OBS" sources, I have added a "Mic" and selected the "Oneplus wireless bullets 2" (on the screenshot is "Sennheiser" for working, but it is the same), the sound from the mic works:
So, the problem is when I select in sources "Mic" and select the "Oneplus wireless bullets 2", the sound from the system starting being very slow, like a zombie's voice :) When I choose some another mic device - it okay, works perfect.
Tried to use the same logic but without "EqMac" app - does not work, i.e. zombie's sound is present.
Guys, any ideas on how to fix this problem? Maybe someone faced with the same but with other headphones with Bluetooth?
Please, help.
Thank you
Narcogen
Is OBS set to 48khz sample rate in Settings > Audio?
Also, some bluetooth headsets will not function as expected in OBS-- you may experience a problem where you cannot simultaneously use them for input and output.
VegaDesign
Yes, here is a screenshot:
It is very bad (((
Narcogen
Also you may get an echo because it looks like there you've added your headset directly, and then added output from eq2 which you indicated was your microphone run through an EQ.
