Question / Help OBS64 process starts and stops 32bit works fine
Kusunagi
Hi all
Been using OBS for over a year always the 64bit version, recently in the last week i can only run the 32bit one as 64bit starts and stops. Just see the process start and then dissapear never get the obs window.
Nothing in appdata\obsstudio\crashes
Event log shows
Faulting application name: obs64.exe, version: 0.0.0.0, time stamp: 0x58be24b4
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x000000000141c46c
Faulting process id: 0x117c
Faulting application start time: 0x01d2a4ec2d971d16
Faulting application path: C:\Program Files (x86)\obs-studio\bin\64bit\obs64.exe
Faulting module path: unknown
Report Id: 6c0ea3ce-10df-11e7-9b6b-d05099328248
HELPFUL!
And this
Fault bucket 387516913, type 27
Event Name: BEX64
Response: Not available
Cab Id: 0
Problem signature:
P1: obs64.exe
P2: 0.0.0.0
P3: 58be24b4
P4: StackHash_bbf1
P5: 0.0.0.0
P6: 00000000
P7: 000000000141c46c
P8: c0000005
P9: 0000000000000008
P10:
C:\Users\kusunagi\AppData\Local\Temp\WER9F2B.tmp.WERInternalMetadata.xml
These files may be available here:
C:\Users\kusunagi\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_obs64.exe_ef145fdd3951b191da21fa8c88a44d5a2a95f0_0d3ea2a4
Analysis symbol:
Rechecking for solution: 0
Path to xml file doesnt exist
But the wer report contains this
Version=1
EventType=BEX64
EventTime=131348667728637158
ReportType=2
Consent=1
UploadTime=131348667728847170
ReportIdentifier=1757655d-10de-11e7-9b6b-d05099328248
IntegratorReportIdentifier=1757655c-10de-11e7-9b6b-d05099328248
Response.BucketId=387516913
Response.BucketTable=27
Response.type=4
Sig[0].Name=Application Name
Sig[0].Value=obs64.exe
Sig[1].Name=Application Version
Sig[1].Value=0.0.0.0
Sig[2].Name=Application Timestamp
Sig[2].Value=58be24b4
Sig[3].Name=Fault Module Name
Sig[3].Value=StackHash_bbf1
Sig[4].Name=Fault Module Version
Sig[4].Value=0.0.0.0
Sig[5].Name=Fault Module Timestamp
Sig[5].Value=00000000
Sig[6].Name=Exception Offset
Sig[6].Value=000000000141c46c
Sig[7].Name=Exception Code
Sig[7].Value=c0000005
Sig[8].Name=Exception Data
Sig[8].Value=0000000000000008
DynamicSig[1].Name=OS Version
DynamicSig[1].Value=6.1.7601.2.1.0.256.1
DynamicSig[2].Name=Locale ID
DynamicSig[2].Value=1033
DynamicSig[22].Name=Additional Information 1
DynamicSig[22].Value=bbf1
DynamicSig[23].Name=Additional Information 2
DynamicSig[23].Value=bbf19df833901531d47f36905d932bf5
DynamicSig[24].Name=Additional Information 3
DynamicSig[24].Value=f231
DynamicSig[25].Name=Additional Information 4
DynamicSig[25].Value=f2313a1f9e7e1fa2e4b38c96eb8f3e0a
UI[2]=C:\Program Files (x86)\obs-studio\bin\64bit\obs64.exe
UI[3]=obs64.exe has stopped working
UI[4]=Windows can check online for a solution to the problem.
UI[5]=Check online for a solution and close the program
UI[6]=Check online for a solution later and close the program
UI[7]=Close the program
LoadedModule[0]=C:\Program Files (x86)\obs-studio\bin\64bit\obs64.exe
LoadedModule[1]=C:\Windows\SYSTEM32\ntdll.dll
LoadedModule[2]=C:\Windows\system32\kernel32.dll
LoadedModule[3]=C:\Windows\system32\KERNELBASE.dll
LoadedModule[4]=C:\Windows\system32\USER32.dll
LoadedModule[5]=C:\Windows\system32\GDI32.dll
LoadedModule[6]=C:\Windows\system32\LPK.dll
LoadedModule[7]=C:\Windows\system32\USP10.dll
LoadedModule[8]=C:\Windows\system32\msvcrt.dll
LoadedModule[9]=C:\Windows\system32\SHELL32.dll
LoadedModule[10]=C:\Windows\system32\SHLWAPI.dll
LoadedModule[11]=C:\Windows\system32\ADVAPI32.dll
LoadedModule[12]=C:\Windows\SYSTEM32\sechost.dll
LoadedModule[13]=C:\Windows\system32\RPCRT4.dll
LoadedModule[14]=C:\Program Files (x86)\obs-studio\bin\64bit\Qt5Widgets.dll
LoadedModule[15]=C:\Program Files (x86)\obs-studio\bin\64bit\Qt5Gui.dll
LoadedModule[16]=C:\Windows\system32\ole32.dll
LoadedModule[17]=C:\Program Files (x86)\obs-studio\bin\64bit\libGLESv2.dll
LoadedModule[18]=C:\Windows\system32\d3d9.dll
LoadedModule[19]=C:\Windows\system32\VERSION.dll
LoadedModule[20]=C:\Windows\system32\d3d8thk.dll
LoadedModule[21]=C:\Windows\system32\dwmapi.dll
LoadedModule[22]=C:\Windows\system32\MSVCP120.dll
LoadedModule[23]=C:\Windows\system32\MSVCR120.dll
LoadedModule[24]=C:\Program Files (x86)\obs-studio\bin\64bit\Qt5Core.dll
LoadedModule[25]=C:\Windows\system32\WS2_32.dll
LoadedModule[26]=C:\Windows\system32\NSI.dll
LoadedModule[27]=C:\Windows\system32\MPR.dll
LoadedModule[28]=C:\Program Files (x86)\obs-studio\bin\64bit\obs-frontend-api.dll
LoadedModule[29]=C:\Program Files (x86)\obs-studio\bin\64bit\obs.dll
LoadedModule[30]=C:\Windows\system32\WINMM.dll
LoadedModule[31]=C:\Program Files (x86)\obs-studio\bin\64bit\w32-pthreads.dll
LoadedModule[32]=C:\Program Files (x86)\obs-studio\bin\64bit\avcodec-57.dll
LoadedModule[33]=C:\Program Files (x86)\obs-studio\bin\64bit\libopus-0.dll
LoadedModule[34]=C:\Program Files (x86)\obs-studio\bin\64bit\libvorbis-0.dll
LoadedModule[35]=C:\Program Files (x86)\obs-studio\bin\64bit\libogg-0.dll
LoadedModule[36]=C:\Program Files (x86)\obs-studio\bin\64bit\libvorbisenc-2.dll
LoadedModule[37]=C:\Program Files (x86)\obs-studio\bin\64bit\libvpx-1.dll
LoadedModule[38]=C:\Program Files (x86)\obs-studio\bin\64bit\libx264-148.dll
LoadedModule[39]=C:\Program Files (x86)\obs-studio\bin\64bit\zlib.dll
LoadedModule[40]=C:\Program Files (x86)\obs-studio\bin\64bit\avutil-55.dll
LoadedModule[41]=C:\Program Files (x86)\obs-studio\bin\64bit\swresample-2.dll
LoadedModule[42]=C:\Program Files (x86)\obs-studio\bin\64bit\avformat-57.dll
LoadedModule[43]=C:\Windows\system32\Secur32.dll
LoadedModule[44]=C:\Windows\system32\SSPICLI.DLL
LoadedModule[45]=C:\Program Files (x86)\obs-studio\bin\64bit\swscale-4.dll
LoadedModule[46]=C:\Program Files (x86)\obs-studio\bin\64bit\libcurl.dll
LoadedModule[47]=C:\Windows\system32\WLDAP32.dll
LoadedModule[48]=C:\Windows\system32\Normaliz.dll
LoadedModule[49]=C:\Windows\system32\CRYPT32.dll
LoadedModule[50]=C:\Windows\system32\MSASN1.dll
LoadedModule[51]=C:\Program Files (x86)\obs-studio\bin\64bit\avdevice-57.dll
LoadedModule[52]=C:\Windows\system32\AVICAP32.dll
LoadedModule[53]=C:\Windows\system32\MSVFW32.dll
LoadedModule[54]=C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.7601.18837_none_a4d981ff711297b6\COMCTL32.dll
LoadedModule[55]=C:\Windows\system32\OLEAUT32.dll
LoadedModule[56]=C:\Program Files (x86)\obs-studio\bin\64bit\avfilter-6.dll
LoadedModule[57]=C:\Windows\system32\IMM32.DLL
LoadedModule[58]=C:\Windows\system32\MSCTF.dll
LoadedModule[59]=C:\Windows\system32\cryptbase.dll
LoadedModule[60]=C:\Windows\system32\profapi.dll
LoadedModule[61]=C:\Program Files (x86)\obs-studio\bin\64bit\platforms\qwindows.dll
LoadedModule[62]=C:\Windows\system32\uxtheme.dll
LoadedModule[63]=C:\Windows\system32\dwrite.dll
LoadedModule[64]=C:\Program Files (x86)\obs-studio\bin\64bit\libobs-d3d11.dll
LoadedModule[65]=C:\Windows\system32\d3d11.dll
LoadedModule[66]=C:\Windows\system32\dxgi.dll
LoadedModule[67]=C:\Windows\system32\WINTRUST.dll
LoadedModule[68]=C:\Windows\system32\D3DCompiler_47.dll
LoadedModule[69]=C:\Windows\system32\nvwgf2umx.dll
LoadedModule[70]=C:\Windows\system32\bcrypt.dll
LoadedModule[71]=C:\Windows\system32\nvspcap64.dll
LoadedModule[72]=C:\Windows\system32\SETUPAPI.dll
LoadedModule[73]=C:\Windows\system32\CFGMGR32.dll
LoadedModule[74]=C:\Windows\system32\DEVOBJ.dll
LoadedModule[75]=C:\Windows\system32\PSAPI.DLL
LoadedModule[76]=C:\Windows\system32\WINHTTP.dll
LoadedModule[77]=C:\Windows\system32\webio.dll
LoadedModule[78]=C:\Windows\system32\WTSAPI32.dll
LoadedModule[79]=C:\Windows\system32\nvapi64.dll
LoadedModule[80]=C:\Windows\system32\bcryptprimitives.dll
LoadedModule[81]=C:\Windows\system32\CLBCatQ.DLL
LoadedModule[82]=C:\Windows\system32\CRYPTSP.dll
LoadedModule[83]=C:\Windows\system32\rsaenh.dll
LoadedModule[84]=C:\Windows\system32\RpcRtRemote.dll
LoadedModule[85]=C:\Windows\system32\SXS.DLL
LoadedModule[86]=C:\Program Files (x86)\obs-studio\obs-plugins\64bit\chrome_elf.dll
LoadedModule[87]=C:\Windows\system32\api-ms-win-core-synch-l1-2-0.DLL
LoadedModule[88]=C:\Program Files (x86)\obs-studio\obs-plugins\64bit\coreaudio-encoder.dll
LoadedModule[89]=C:\Program Files (x86)\obs-studio\obs-plugins\64bit\enc-amf.dll
LoadedModule[90]=C:\Program Files (x86)\obs-studio\obs-plugins\64bit\frontend-tools.dll
LoadedModule[91]=C:\Program Files (x86)\obs-studio\obs-plugins\64bit\image-source.dll
LoadedModule[92]=C:\Program Files (x86)\obs-studio\obs-plugins\64bit\libcef.dll
LoadedModule[93]=C:\Windows\system32\USERENV.dll
LoadedModule[94]=C:\Windows\system32\OLEACC.dll
LoadedModule[95]=C:\Windows\system32\COMDLG32.dll
LoadedModule[96]=C:\Windows\system32\dbghelp.dll
LoadedModule[97]=C:\Windows\system32\WINSPOOL.DRV
LoadedModule[98]=C:\Windows\system32\credui.dll
LoadedModule[99]=C:\Windows\system32\CRYPTUI.dll
LoadedModule[100]=C:\Windows\system32\NETAPI32.dll
LoadedModule[101]=C:\Windows\system32\netutils.dll
LoadedModule[102]=C:\Windows\system32\srvcli.dll
LoadedModule[103]=C:\Windows\system32\wkscli.dll
LoadedModule[104]=C:\Windows\system32\SAMCLI.DLL
LoadedModule[105]=C:\Windows\system32\IPHLPAPI.DLL
LoadedModule[106]=C:\Windows\system32\WINNSI.DLL
LoadedModule[107]=C:\Windows\system32\ncrypt.dll
LoadedModule[108]=C:\Windows\system32\urlmon.dll
LoadedModule[109]=C:\Windows\system32\api-ms-win-downlevel-ole32-l1-1-0.dll
LoadedModule[110]=C:\Windows\system32\api-ms-win-downlevel-shlwapi-l1-1-0.dll
LoadedModule[111]=C:\Windows\system32\api-ms-win-downlevel-advapi32-l1-1-0.dll
LoadedModule[112]=C:\Windows\system32\api-ms-win-downlevel-user32-l1-1-0.dll
LoadedModule[113]=C:\Windows\system32\api-ms-win-downlevel-version-l1-1-0.dll
LoadedModule[114]=C:\Windows\system32\api-ms-win-downlevel-normaliz-l1-1-0.dll
LoadedModule[115]=C:\Windows\system32\iertutil.dll
LoadedModule[116]=C:\Windows\system32\WININET.dll
LoadedModule[117]=C:\Windows\system32\dxva2.dll
LoadedModule[118]=C:\Windows\system32\FONTSUB.dll
LoadedModule[119]=C:\Windows\system32\dhcpcsvc.DLL
LoadedModule[120]=C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18837_none_fa3b1e3d17594757\comctl32.dll
LoadedModule[121]=C:\Program Files (x86)\obs-studio\obs-plugins\64bit\libEGL.dll
LoadedModule[122]=C:\Program Files (x86)\obs-studio\obs-plugins\64bit\libGLESv2.dll
LoadedModule[123]=C:\Program Files (x86)\obs-studio\obs-plugins\64bit\obs-browser.dll
LoadedModule[124]=C:\Program Files (x86)\obs-studio\obs-plugins\64bit\obs-ffmpeg.dll
LoadedModule[125]=C:\Program Files (x86)\obs-studio\obs-plugins\64bit\obs-filters.dll
LoadedModule[126]=C:\Program Files (x86)\obs-studio\obs-plugins\64bit\obs-outputs.dll
LoadedModule[127]=C:\Program Files (x86)\obs-studio\obs-plugins\64bit\obs-qsv11.dll
LoadedModule[128]=C:\Program Files\Intel\Media SDK\libmfxhw64.dll
State[0].Key=Transport.DoneStage1
State[0].Value=1
State[1].Key=DataRequest
State[1].Value=Bucket=387516913/nBucketTable=27/nResponse=1/n
FriendlyEventName=Stopped working
ConsentKey=BEX64
AppName=obs64.exe
AppPath=C:\Program Files (x86)\obs-studio\bin\64bit\obs64.exe
Ive removed all prog and appdata folders to do with OBS tried removing and reinstalling version 17 and 18.01 both do the same thing.
Run as admin, all that SFC /SCANNOW
MSCONFIG disable all startup and non MS services but no joy.
So stuck please heeeeellllppp I need to stream!
Thanks
