OBS Wont Open and when it does it crashes. Need Help ASAP
MaxN-H
Every time I open obs it seems to not open fully then crashes, I've just updated to the latest version. It was working fine yesterday but won't today. My mac is a Catalina 10.15. I Have tried reinstalling and still no luck. I Have to use it on Saturday so need help asap. Thanks :)
Nobsyde
got to \Library\Application Support in finder, and rename "obs-studio" in "old-obs-studio".
Start obs - it should now open and create a new obs-studio folder.
You'll need to reset everything, but you could try and copy stuff from "basic" inside "old-obs-studio" - it has your old profile + scenes. However, chances are that obs might still crash, if the scenes are culprit, so it could be difficult.
