Question / Help OBS When Streaming Audio Makes Popping Noise
Jesse Gonzales
So i've been testing my stream and such and everything was perfectly fine until the audio issues. I tried everything uninstalled obs, change headset, and update drivers. Whenever I'm streaming my audio would stop and start making a popping noise until i un plug the usb and plug it back in it restores it but im trying to know a fix permanently. ( Off Stream i have no issues only during stream )
Jesse Gonzales
This is my log
22:01:54.477: CPU Name: AMD FX(tm)-6300 Six-Core Processor
22:01:54.477: CPU Speed: 3516MHz
22:01:54.477: Physical Cores: 3, Logical Cores: 6
22:01:54.477: Physical Memory: 8173MB Total, 6151MB Free
22:01:54.477: Windows Version: 10.0 Build 14393 (revision: 953; 64-bit)
22:01:54.477: Running as administrator: false
22:01:54.477: Aero is Enabled (Aero is always on for windows 8 and above)
22:01:54.478: Portable mode: false
22:01:54.553: OBS 18.0.1 (64bit, windows)
22:01:54.553: ---------------------------------
22:01:54.554: ---------------------------------
22:01:54.554: audio settings reset:
22:01:54.554: samples per sec: 48000
22:01:54.554: speakers: 2
22:01:55.313: Warning: The OpenGL renderer is currently in use. On windows, the OpenGL renderer can decrease capture performance due to the lack of specific features used to maximize capture performance. The Direct3D 11 renderer is recommended instead.
22:01:55.421: ---------------------------------
22:01:55.421: video settings reset:
22:01:55.421: base resolution: 1920x1080
22:01:55.421: output resolution: 1280x720
22:01:55.421: downscale filter: Bilinear
22:01:55.421: fps: 30/1
22:01:55.421: format: NV12
22:01:55.422: Audio monitoring device:
22:01:55.422: name: Speakers (Corsair Gaming H1500 Headset)
22:01:55.422: id: {0.0.0.00000000}.{f13a0541-f21c-44e5-b330-fbadfdf01127}
22:01:55.422: ---------------------------------
22:01:55.425: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
22:01:55.441: [CoreAudio encoder]: Adding CoreAudio AAC encoder
22:01:55.475: [AMF Encoder] Version 1.4.3.11 loaded (Compiled: 1.3.0.5, Runtime: 1.4.1.0, Library: 1;4;1;0;16.60.2011;201702100916;CL#1371796).
22:01:58.027: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
22:01:58.028: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
22:01:58.029: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
22:01:58.030: Failed to load 'en-US' text for module: 'obs-browser.dll'
22:01:58.030: [browser_source: 'Version: 1.29.0']
22:01:58.032: LoadLibrary failed for 'nvEncodeAPI64.dll': The specified module could not be found.
22:01:58.032: (126)
22:01:58.347: Couldn't find VLC installation, VLC video source disabled
22:01:58.357: No blackmagic support
22:01:58.539: ---------------------------------
22:01:58.539: Loaded Modules:
22:01:58.539: win-wasapi.dll
22:01:58.539: win-mf.dll
22:01:58.539: win-dshow.dll
22:01:58.539: win-decklink.dll
22:01:58.539: win-capture.dll
22:01:58.539: vlc-video.dll
22:01:58.539: text-freetype2.dll
22:01:58.539: rtmp-services.dll
22:01:58.539: obs-x264.dll
22:01:58.539: obs-vst.dll
22:01:58.539: obs-transitions.dll
22:01:58.539: obs-text.dll
22:01:58.539: obs-qsv11.dll
22:01:58.539: obs-outputs.dll
22:01:58.539: obs-filters.dll
22:01:58.539: obs-ffmpeg.dll
22:01:58.539: obs-browser.dll
22:01:58.539: image-source.dll
22:01:58.539: frontend-tools.dll
22:01:58.539: enc-amf.dll
22:01:58.539: coreaudio-encoder.dll
22:01:58.540: ==== Startup complete ===============================================
22:01:58.613: All scene data cleared
22:01:58.613: ------------------------------------------------
22:01:58.624: [WASAPISource::TryInitialize]:[Speakers (2- Corsair Gaming H1500 Headset)] Failed to activate client context: 88890004
22:01:58.624: [WASAPISource::WASAPISource] Device '{0.0.0.00000000}.{022f9821-85d8-4149-b48e-85061118a0d6}' not found. Waiting for device
22:01:58.629: [WASAPISource::TryInitialize]:[Microphone (Samson C01U )] Failed to activate client context: 88890004
22:01:58.629: [WASAPISource::WASAPISource] Device '{0.0.1.00000000}.{bbb83e89-a1d2-4638-94d3-7abde145cb18}' not found. Waiting for device
22:01:58.629: source 'Mic/Aux' enabled push-to-mute
22:02:00.484: Switched to scene 'H1Z1'
22:02:00.486: ------------------------------------------------
22:02:00.486: Loaded scenes:
22:02:00.486: - scene 'Scene':
22:02:00.486: - scene 'H1Z1':
22:02:00.507: - source: 'Game ' (game_capture)
22:02:00.508: - filter: 'Color Correction' (color_filter)
22:02:00.508: - source: 'Overlay' (image_source)
22:02:00.508: - source: 'Recent Donation' (text_gdiplus)
22:02:00.508: - filter: 'Scroll' (scroll_filter)
22:02:00.508: - source: 'Song' (text_gdiplus)
22:02:00.508: - source: 'Chat Box' (browser_source)
22:02:00.508: - source: 'Recent Follower' (text_gdiplus)
22:02:00.508: - source: 'Event List' (browser_source)
22:02:00.508: - source: 'Revlo Alert' (browser_source)
22:02:00.508: - source: 'Donation Goal' (browser_source)
22:02:00.508: - source: 'Twitch Alerts' (browser_source)
22:02:00.508: - scene 'Window Capture':
22:02:00.508: - source: 'Display Capture' (monitor_capture)
22:02:00.508: ------------------------------------------------
22:03:10.491: Settings changed (outputs)
22:03:10.491: ------------------------------------------------
22:17:00.376: WASAPI: Device 'Speakers (Corsair Gaming H1500 Headset)' initialized
22:17:00.420: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds
22:17:01.089: WASAPI: Device 'Microphone (3- Samson C01U )' initialized
22:17:01.291: Settings changed (general, audio)
22:17:01.291: ------------------------------------------------
22:19:46.770: adding 21 milliseconds of audio buffering, total audio buffering is now 64 milliseconds
