OBS Using WYZE and EUFY Wifi Cams plus PTZ Control
trgrassijr
Hello
Running OBS 30.1.2 64 bit on my windows 11 Laptop.
I have two types of CAMs
(4) WYZE and (8) EUFY
total of 12 Cams now planning for couple more.
They are connect using RTSP
I have 3 issues
The scenes show blank I must click on the source go to properties and then click OK after I do that the screen shows the scene.
Some Scenes the source appears but most are blank and I have to go thru what I did above on each.
From my phone app for the cams I see the view no problem.
Issue two is if I have a scene displayed on OBS for a long time the source does not refresh.
How do a refresh a source.
I have been clicking on the close source icon and then clicking it back on but that does not help
I need to go to my phone app and refresh the RTSP setting make no changes just close the app and then it refreshes on OBS
I recently got a new EUFY PAN and TILT CAM. Connected it to OBS using RTSP.
It has same issues as above.
I also installed the plugin for PTZ controls and that does not work the camera at all.
Does the EUFY work with VISCA over IP ? I used port 1259 and 52381 but no luck
When the source is active on OBS I can move the CAM with my phone app and the scene is updated.
Any ideas or suggestions
Thank you
Tom
