Question / Help OBS Studio problem. Drop connection 0kbps
Szopenowsky
Hello. I have the problem with OBS Studio. When i am broadcasting live stream, the upload on OBS Studio drops to 0 kbps, first time after about 40 sec, next time after 4 min, and next time after 1-2 hours of stream. Standart uploading during streaming is 2100-2400kbps. There is no error notifications. I don't have any connection problems. Can you help me solve this problem?
https://gist.github.com/anonymous/dcf0747619aec8c49ad977a7e25247c7
and
http://pastebin.com/D9yBArC7
EBrito
First log
21:51:29.157: Output 'simple_stream': Number of lagged frames due to rendering lag/stalls: 1 (0.0%)
Second log
18:36:33.293: Output 'simple_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 33 (0.9%)
18:41:56.811: Output 'simple_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 86 (1.0%)
19:44:39.193: Output 'simple_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 22 (0.0%)
20:18:02.988: Output 'simple_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 76 (0.1%)
20:57:50.596: Output 'simple_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 234 (0.3%)
Minor network issues.
Try another Twitch server
http://www.teamliquid.net/forum/tech-support/478845-twitchtest-twitch-bandwidth-tester
Use 64K TCP Windo and 60 sec
Choose any above 80 (quality)
Also, you can fine tune your TCP/IP with TCPOptimizer
http://www.speedguide.net/downloads.php
Szopenowsky
First log
Second log
Look this is speedtest:
And this is TwitchTest - I using Server: EU Warsaw, Poland
I can stream 3000-3500kbps bitrate and only sometimes i have drop frames ( mostly is 0.3% drop frames { 6-7h stream} )
60s test:
