Question / Help OBS-Studio - No sound with Avermedia Live Gamer Extreme
Trinoo
Hello,
today i wanted to change from the the good old OBS to the Studio-Version, but unfortunately i have no sound with my Avermedia Live Gamer Extreme.
With the old OBS version ( not studio ) everything works perfectly.
someone has an idea or even the solution for my problem ?
greetings
  • 2016-03-17 17-45-40.txt
Ringtext
I have the same problem, and after messing around, I have found a workaround.
So, here is what I did.
In Sources add "Audio Output Capture" and "Video Capture Device".
In "Video Capture Device" properties select "AVerMedia GC550 Video Capture ", scroll down to "Audio Output Mode" and select "Output to desktop".
The "Audio Capture Device" is capturing the desktop audio that we set in the "Video Capture Device" properties.
I hope this helps.
darkangelpt
It sure works.
I dont know if there's s any delay like that.
But still trying to make my capture card sound go directly. And not by workarrounds
