FunnyManKoss
So recently Iv been having a weird problem with my OBS. Recently every time I stream my audio has been cutting in and out, it starts off slow then picks up to every couple of seconds. When the audio cuts out it cuts out all audio on my computer then restores within seconds but one thing it does is cut out my discord audio so I half to leave and rejoin my server for me to hear my friends again even though my voice never cuts out for them. Iv tried a couple of things to fixs this issue like...
- Reinstall OBS studio
- Fully uninstall OBS and get a later version (I'v gotten OBS studios 20.0 and 19.0.3)
- Iv almost disabled my face cam because I thought the face came mic was affecting something
- Iv done some small things like change some small settings
- I also reinstalled OBS on different hard drives
00:57:30: CLR host plugin strings not found, dynamically loading 4 strings
00:57:30: CLRHost::Initialize() attempting to load and start the .NET runtime (null)
00:57:30: CLRHost::Initialize() Found version v2.0.50727 .NET runtime
00:57:30: CLRHost::Initialize() Found version v4.0.30319 .NET runtime
00:57:30: CLRHost::Initialize() attempting to use v4.0.30319 .NET runtime
00:57:31: CLRHost::LoadInteropLibrary() load the assembly plugins\CLRHostPlugin\CLRHost.Interop.dll
00:57:36: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRBrowserSourcePlugin
00:57:39: CLRHost:: Could not find/load browser settings at location C:\Users\KingofImperials\AppData\Roaming\OBS\pluginData\browser.json
00:57:39: CLRHost:: Exception: System.IO.FileNotFoundException: Could not find file 'C:\Users\KingofImperials\AppData\Roaming\OBS\pluginData\browser.json'.
00:57:39: File name: 'C:\Users\KingofImperials\AppData\Roaming\OBS\pluginData\browser.json'
00:57:39: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
00:57:39: at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
00:57:39: at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
00:57:39: at CLRBrowserSourcePlugin.Shared.BrowserSettings.Reload()
00:57:47: CLRHost::LoadPlugins() successfully added CLR plugin [Type: CLRBrowserSourcePlugin.CLRBrowserSourcePlugin, Name: CLR Browser Source Plugin]
00:58:15: CLR host plugin instance deleted; removing dynamically loaded localization strings
Last game capture log:
2017-10-02, 15:38:55: we're booting up:
15:38:55: CaptureThread: attached to process TslGame.exe
15:38:57: D3D9 Present
15:38:57: DXGI Present
15:38:57: GL Present
15:38:57: (half life scientist) everything.. seems to be in order
15:38:57: DXGI: Found D3D 11
15:38:57: setting up d3d11 data
15:38:57: ---------------------- Cleared D3D11 Capture ----------------------
15:38:57: found dxgi format (dx11) of: 24, size: {1920, 1080}, multisampled: false
15:38:57: DoD3D11Hook: success
15:39:01: successfully capturing d3d11 frames via GPU
15:39:33: stop requested, terminating d3d11 capture
15:39:33: ---------------------- Cleared D3D11 Capture ----------------------
