Hello! :)
Having an issue with both streaming / recording using OBS Studio 64bit.
I'll use a series of images to explain my setup and outline the issues I am having as best as I can, for you, the potential Wizard who can hopefully help me fix this.
The problem I am having is to do with Audio. I am using the 4 Track Multi-track recording, with Track 1 being everything (Livestreaming for example uses this track) Track 2 is for my Mic, Track 3 for Discord/Skype call, and finally Track 4 for Gameplay.
I have my recordings set to export as .mp4 - I'd like to use a more reliable output but afaik none of the other types open with Sony Vegas Pro (what I use to edit videos)
When I record or livestream (or both at same time), everything is fine on my end, but a loud electronic sounding POP can be heard for the livestream viewers, or in the recording. This can happen on both channels, but can also happen just on left audio channel, or the right.
What is very strange is that even though Track 1 has all audio, the pop may occur on Track 2, but NOT on track 1, and vice versa.
Here are some examples of how the audio pops look in the audio waveform in the editing timeline of Sony Vegas.
In this one, the pop can be seen happening on Track 3 (Discord/Skype) But NOT in Track 1, where Discord is also present.
1. http://imgur.com/a/3sLil
This one was a quick test livestream and the pops are happening in Track 1 & 4, but the pops in each track are unique from eachother
2. http://imgur.com/a/Zh0tR
Here are some screens of my OBS Studio 64bit settings.
Output - Streaming Tab
1. http://imgur.com/a/PvTcm
Output - Recording Tab
2. http://imgur.com/a/YSq3G
Output - Audio Tab
3. http://imgur.com/a/VJr84
Audio
1. http://imgur.com/a/vM783
Video
1. http://imgur.com/a/Gxu4e
Advanced
1. http://imgur.com/a/zly5N
Audio Mixer
1. http://imgur.com/a/2Q4yP
Elgato
1. http://imgur.com/a/pmUnB
Properties for Elgato
1. http://imgur.com/a/P21Ns
2. http://imgur.com/a/ddwNs
Here is a quick 34 second edited recording of instances where the Audio pop occurs if your curious as to how it sounds.
https://www.youtube.com/watch?v=ywf1vwI7-Vo
I hope that's everything, see below for what I use in my setup and log files!
Thanks for reading!
My Setup :
ASUS Z170 Pro Gaming Motherboard,
EVGA FTW GTX 1070
Ripjawz 2133Mhz DDR4 16GB Ram
Sound Blaster Z PCI Sound Card
Behringer Xenyx QX1002USB Premium 10 Input 2 Bus Mixer
Rode NT1-A XLR Condenser Mic
Elgato HD60 Pro PCI
Log Files:
Last Log File : https://gist.github.com/e5049924dd7a60a4daea687e69939ab7
Current Log File https://gist.github.com/7fcebbe82c24d29177f0eabd911eb70c
Output - Audio Tab
Audio
Video
Advanced
Audio Mixer
Elgato
Thanks for reading!
My Setup :
EVGA FTW GTX 1070
Elgato HD60 Pro PCI
Log Files:
