Question / Help OBS Stream FPS Problem Help!!
EmptyPlate
Hi, I am trying to stream Fortnite (720p, Full screen) with OBS and I find that whenever I start streaming/recording and tab in to the game, the stream becomes very choppy but only when the fps isn't constant i.e. not constant 60fps I tried to work around this by capping the frame rate to 60 but it is still sometimes choppy, it is the same with recording. My native resolution is 1080p (if I play the game at 1080p, it goes under 60fps, which I don't want).
I set the OBS to stream with the GPU in the NVIDIA settings, as a black screen is shown if I use the CPU. I also do not want to put the game into windowed mode as the fps of the actual game drops drastically.
Another problem is that I can't choose the NVENC encoder otherwise it says that I couldn't start recording/streaming, but the log says it is supported?
Also I'm trying to stream with a single laptop (I know, I should probably get a desktop PC ~ don't have money :/)
Here is my log file when recording one game of Fortnite:
https://hastebin.com/urisipemim
It would be great if someone could help :)
Specs:
OS Name Microsoft Windows 10 Home
Version 10.0.17134 Build 17134
System Model HP ENVY TS 15 Notebook PC
Processor Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz, 2401 Mhz, 4 Core(s), 8 Logical Processor(s)
Graphics Processor GeForce 840M 2GB ~ Overclocked (Memory: +195Hz and Core: +135Hz)
Installed RAM 12.0GB
HCS_Gaming
You are getting encoding and rendering lags.
I dont think you can stream very well with your notebook, because of the CPU and also GPU.
Did you check your upload speed? If not, use this: https://r1ch.net/projects/twitchtest
try lowering your settings ingame and in OBS.
Try 30fps instead of 60 fps.
Downscaling filter to billinear.
You wont be able to stream at 60fps, specially a fast pace game like fortnite.
