Obs sound settings help
richie86
I'm looking to set up a recording studio for my wife and she is having trouble hearing clapping like it's not picking it up in the sound bars. Any help much appreciated
Everything is on default settings
AaronD
Default is good to show that "something" works, fresh out of the box and knowing nothing. Beyond that, it's a liability. Always choose a specific device, and Disable what you're not using. Then you won't have Default randomly switch to something else and kill your rig. (because it will)
So, Disable and remove everything (keep your workspace clean), figure out which device is your mic, choose that specifically, and see if it works.
