OBS sound is not recorded
theshuk
OBS is picked up my desktop and mic audio but as soon as I click Start Recording, the audios are not recorded.
I just got new headphones the Razor Kitty edition which has a built in mic. Also when i clicked on the mic(as instruction by Razor to turn on the mic) it mutes on OBS?? Here are some other settings;
Any help would be great :)
Regards,
Shuk
carlmmii
You're recording your audio sources to separate audio tracks. In order to hear those back in the recording, you have to switch to the specific audio track (in VLC, this is under the Audio menu dropdown).
In general, if you want to keep a track for general listening but also keep isolated tracks, you can keep track 1 selected for all your audio sources, and then have the other tracks selected to the individual inputs.
For example, desktop audio would be enabled on tracks 1&2, and your mic would be enabled on tracks 1&3. This would mean that audio track 1 has the full mix, while track 2 would have only your desktop audio, and track 3 would have only your mic.
