Hello all. I've recently just bought a HDMI to USB capture card dongle from Amazon and have it capturing a Firestick output to my MacBook. Picture is absolutely fine. Problem is, I can only capture mono sound from the stream. I've tried every kind of audio setting on OBS, the MacBook and on the Firestick but to no avail. System Preferences sees it as USB3. 0 capture. The selected device has no input controls.
So, after a lot of web searching I've come across what may be the problem. It's the capture card's audio output. Apparently a lot of the cheaper Chinese made dongles output audio as 1 channel 96khz 16 bit (2 x 48khz channels combined) which my Mac only sees as 1 channel of audio. Audio Midi utility shows it as USB 3.0 capture 1 in / 0 out with Format - 96,000 hz 1 ch 16 bit integer. There is no way to alter this via this utility.
My question is, is there a workaround for this? Can I use a specific piece of software or a Terminal command to split the audio stream coming in via USB to the correct stereo channels? Any advice would be greatly appreciated!
System Information shows the card as follows:
USB3. 0 capture:
Product ID: 0x2109
Vendor ID: 0x534d
Version: 21.00
Speed: Up to 480 Mb/s
Manufacturer: MACROSILICON
Location ID: 0x14200000 / 6
Current Available (mA): 500
Current Required (mA): 500
Extra Operating Current (mA): 0
MacBook Pro 9.1 running Catalina 10.15.7 (maximum available on this model))
OBS version 19.0.2 - 64 bit (maximum available on this model)
USB3. 0 capture:
Product ID: 0x2109
Vendor ID: 0x534d
Version: 21.00
