Bitbatgaming
OBS is not switching to integrated graphics despite being set to integrated graphics in control panel.
As you can see in the log file, it is still switching to the nvidia graphics. Keep in mind that this is a laptop.
20:21:52.066: CPU Name: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
20:21:52.066: CPU Speed: 2208MHz
20:21:52.066: Physical Cores: 6, Logical Cores: 12
20:21:52.066: Physical Memory: 16178MB Total, 7739MB Free
20:21:52.066: Windows Version: 10.0 Build 18362 (release: 1909; revision: 1256; 64-bit)
20:21:52.066: Running as administrator: true
20:21:52.066: Aero is Enabled (Aero is always on for windows 8 and above)
20:21:52.067: Windows 10 Gaming Features:
20:21:52.067: Game Bar: On
20:21:52.067: Game DVR: On
20:21:52.067: Game DVR Background Recording: Off
20:21:52.067: Game Mode: Off
20:21:52.069: Sec. Software Status:
20:21:52.070: Windows Defender Antivirus: enabled (AV)
20:21:52.070: Windows Firewall: enabled (FW)
20:21:52.071: Current Date/Time: 2020-12-29, 20:21:52
20:21:52.071: Browser Hardware Acceleration: true
20:21:52.071: Portable mode: false
20:21:52.457: OBS 26.1.0 (64-bit, windows)
20:21:52.457: ---------------------------------
20:21:52.518: ---------------------------------
20:21:52.518: audio settings reset:
20:21:52.518: samples per sec: 48000
20:21:52.518: speakers: 2
20:21:52.519: Initializing D3D11...
20:21:52.519: Available Video Adapters:
20:21:52.526: Adapter 0: NVIDIA GeForce GTX 1060 with Max-Q Design
20:21:52.526: Dedicated VRAM: 2051014656
20:21:52.526: Shared VRAM: 4187111424
20:21:52.526: PCI ID: 10de:1c20
20:21:52.526: Driver Version: 27.21.14.5167
20:21:52.526: output 0: pos={0, 0}, size={1920, 1080}, attached=true, refresh=60, name=
20:21:52.526: Adapter 1: Intel(R) UHD Graphics 630
20:21:52.526: Dedicated VRAM: 134217728
20:21:52.526: PCI ID: 8086:3e9b
20:21:52.527: Driver Version: 26.20.100.8141
20:21:52.529: Loading up D3D11 on adapter NVIDIA GeForce GTX 1060 with Max-Q Design (0)
20:21:52.577: D3D11 loaded successfully, feature level used: b000
20:21:52.577: DXGI increase maximum frame latency success
20:21:52.577: D3D11 GPU priority setup success
20:21:53.229: ---------------------------------
20:21:53.229: video settings reset:
20:21:53.229: base resolution: 1920x1080
20:21:53.229: output resolution: 1920x1080
20:21:53.229: downscale filter: Bicubic
20:21:53.229: fps: 60/1
20:21:53.229: format: NV12
20:21:53.229: YUV mode: 709/Partial
20:21:53.229: NV12 texture support enabled
20:21:53.230: Audio monitoring device:
20:21:53.230: name: Default
20:21:53.230: id: default
20:21:53.239: ---------------------------------
20:21:53.247: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
20:21:53.248: Failed to load 'en-US' text for module: 'decklink-captions.dll'
20:21:53.250: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
20:21:53.290: [AMF] Unable to load 'amfrt64.dll', error code 126.
20:21:53.293: [AMF] AMF Test failed due to one or more errors.
20:21:53.293: Failed to initialize module 'enc-amf.dll'
20:21:53.321: [obs-browser]: Version 2.9.1
20:21:53.322: [obs-browser]: CEF Version 75.1.16+g16a67c4+chromium-75.0.3770.100
20:21:53.325: NVENC supported
20:21:53.351: Failed to load 'en-US' text for module: 'prpr-library.dll'
20:21:53.356: Couldn't find VLC installation, VLC video source disabled
20:21:53.361: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
20:21:53.362: No blackmagic support
20:21:53.366: ---------------------------------
20:21:53.366: Loaded Modules:
20:21:53.366: win-wasapi.dll
20:21:53.366: win-mf.dll
20:21:53.366: win-dshow.dll
20:21:53.366: win-decklink.dll
20:21:53.366: win-capture.dll
20:21:53.366: vlc-video.dll
20:21:53.366: text-freetype2.dll
20:21:53.366: rtmp-services.dll
20:21:53.366: prpr-library.dll
20:21:53.366: obs-x264.dll
20:21:53.366: obs-vst.dll
20:21:53.366: obs-transitions.dll
20:21:53.366: obs-text.dll
20:21:53.366: obs-qsv11.dll
20:21:53.366: obs-outputs.dll
20:21:53.366: obs-filters.dll
20:21:53.366: obs-ffmpeg.dll
20:21:53.366: obs-browser.dll
20:21:53.366: image-source.dll
20:21:53.366: frontend-tools.dll
20:21:53.366: enc-amf.dll
20:21:53.366: decklink-ouput-ui.dll
20:21:53.366: decklink-captions.dll
20:21:53.366: coreaudio-encoder.dll
20:21:53.367: ==== Startup complete ===============================================
20:21:53.387: All scene data cleared
20:21:53.387: ------------------------------------------------
20:21:53.472: WASAPI: Device 'Speakers/Headphones (Realtek(R) Audio)' [48000 Hz] initialized
20:21:53.472: [Loaded global audio device]: 'Desktop Audio'
20:21:53.487: WASAPI: Device 'Microphone (Yeti Stereo Microphone)' [44100 Hz] initialized
20:21:53.498: [Loaded global audio device]: 'Mic/Aux'
20:21:53.498: - filter: 'Noise Gate' (noise_gate_filter)
20:21:53.498: - filter: 'Gain' (gain_filter)
20:21:53.498: - filter: 'Noise Suppression' (noise_suppress_filter_v2)
20:21:53.501: [window-capture: 'Window Capture 2'] update settings:
20:21:53.501: executable: RobloxPlayerBeta.exe
20:21:53.501: method selected: Automatic
20:21:53.501: method chosen: BitBlt
20:21:53.501:
20:21:53.505: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds (source: Desktop Audio)
20:21:53.505:
20:21:53.689: [window-capture: 'Window Capture'] update settings:
20:21:53.689: executable: Discord.exe
20:21:53.689: method selected: Automatic
20:21:53.689: method chosen: WGC
20:21:53.689:
20:21:53.690: [prpr_library] [(null)] initialising prprlive
20:21:53.690: [prpr_library] [PrprLive-αchannel] Named sender not found w: 1, h: -942657636
20:21:53.690: [prpr_library] [PrprLive-αchannel] Sender has changed / gone away. Resetting
20:21:53.791: [prpr_library] Sender name Prpr Camera, total senders 1
20:21:53.791: [prpr_library] [PrprLive-αchannel] Getting info for sender Prpr Camera
20:21:53.791: [prpr_library] [PrprLive-αchannel] Sender Prpr Camera is of dimensions 1920 x 1080
20:21:53.793: [Media Source 'Stinger (Stinger)']: settings:
20:21:53.793: input: D:/Downloads/Stream Assets/Stair Step Stinger.webm
20:21:53.793: input_format: (null)
20:21:53.793: speed: 100
20:21:53.793: is_looping: no
20:21:53.793: is_hw_decoding: yes
20:21:53.793: is_clear_on_media_end: yes
20:21:53.793: restart_on_activate: yes
20:21:53.793: close_when_inactive: no
20:21:53.793: Switched to scene 'Recording (Normal)'
20:21:53.794: ------------------------------------------------
20:21:53.794: Loaded scenes:
20:21:53.794: - scene 'Recording (Normal)':
20:21:53.794: - source: 'Window Capture' (window_capture)
20:21:53.794: - source: 'Window Capture 2' (window_capture)
20:21:53.794: - source: 'PrprLive-αchannel' (spout_capture)
20:21:53.794: - scene 'TanookiAlex Is Offline':
20:21:53.794: - source: 'Image' (image_source)
20:21:53.794: - scene 'TanookiAlex Be Right Back':
20:21:53.794: - source: 'Image 2' (image_source)
20:21:53.798: [prpr_library] [PrprLive-αchannel] rendering context->texture
20:22:01.582: [duplicator-monitor-capture: 'Display Capture'] update settings:
20:22:01.582: display: 1 (1920x1080)
20:22:01.582: cursor: true
20:22:01.592: User added source 'Display Capture' (monitor_capture) to scene 'Recording (Normal)'
20:22:09.483: User Removed source 'Display Capture' (monitor_capture) from scene 'Recording (Normal)'
Need answer please
20:21:53.501:
20:21:53.505:
20:21:53.689:
Need answer please
