How exactly are you doing that because I am using WavTap and I can't hear skype when I set it up like the forum post says to.Since you're on a Mac, you automatically have GarageBand, correct? You could always dump all of your audio sources into GarageBand first, then set GB's output to Soundflower. Then, set OBS's input to receive Soundflower (catching all your audio sources in one). You'd be free to adjust levels in GB as needed.
I do this with Logic for my podcast setup. Works great!
But what exactly am I supposed to do in GarageBand to do this? Do I have to have it open while I'm recording? Like how exactly do you do that?In Audio/MIDI Setup, you can create an Aggregate device from WavTap and your Built-In Output. Then set GB's output as Aggregate Device. The audio should send from GB to both WavTap and the Built-in Output (your mac's headphone jack). Then you can leave OBS audio input as WavTap.
Note, I do this using Soundflower, not WavTap, but I would assume it is a similar routing setup.
Yes I am using soundflower. But obs will only record 1 audio for me.Aren't you using soundflower/wavtap?
I figured it out. All you have to do is open "Audio MIDI Setup" then click the + button and then click multi sound device or something like that. Then check the "Built-in Output" and "Soundflower" (I have WavTap so I checked my WavTap box, and I'm just assuming it's the same.) boxes. Then you right click the multi audio device on the left panel and click use as output. Then go into OBS and go to settings>audio>Desktop Audio and set that to Soundflower (Again, I set this to WavTap because I have WavTap). Then go to skype>Preferences>Audio/Video and then set the output to "Same as system"Yes I am using soundflower. But obs will only record 1 audio for me.
I got it working but i did it a different way!
Hey, so I am trying to have obs record skype "when my friend talks" and my ingame sound at the same time. So I have looked everywhere and can't seem to find help. So I am on here.
Thanks!
