Paul Apps Fine Art
Hi everyone, I am fairly new to OBS and certainly this forum. I have been recording stream footage for later use as an edit in FCPX 10.5.4 There were no issues the streaming feed was the selected encoder.
I then realized that the output was lowered at 720p So researching I changed a number of settings in the OBS output tab. KPS settings and encoder. I used x264, the footage was captured, etc, when bought into FCPX I could see the footage, no issue there. Until I tried to do anything with it. I could not transcode at all. Nor easily scrub without every move seeing the revolving colour parasol for ages, every move was the same and frustrating, I ended up having to crash out each time.
Equally, it would not render or export.
I went back into OBS and test footage in several other settings Apple Hard and software 264. The result was the same. It seems that something in OBS or in the encoders provided is not compatible with FCPX.
I loaded the same footage into Lumafusion 3.0. Although I could see and edit footage, The scrubbing function was not available to edit with. I test the export and it worked. My workaround on this occasion was to export the whole raw footage in the Lumafusion timeline as H264. No problem with that, then to bring that exported film as an H264 Mp4 back into FCPX. At this point, it seems to work as normal, so fingers crossed.
The frustration is that any of this has to happen in this way. I have invested a lot to stream, and record from OBS to my FCPX to edit videos as a workflow in the future.
I pray that you better-informed people out there can help and shed light upon and provide an idiot-proof way to explain and overcome the problems. I thank you all in advance,
Best wishes
Paul
Best wishes
Paul
