OBS dropping sound not audio from Atem Mini Pro for no reason
Maggers
Morning all,
I have a sporadic issue (the worst kind) with OBS. I can be streaming and, regardless of the platform being used and regardless of which computer I use either Windows PC or a Windows laptop both very highly spect pieces of hardware the sound will drop with no reason no warning or otherwise.
I can work around to fix this is by going into the details settings of the Atem "Blackmagic Design" capture device, changing the custom sound from the black magic design to something else such as the webcam microphone and then going back to the black magic design sound source. This is not at all ideal and it's frustrating given there's no rhyme nor reason as to why this happens it just does the visuals continue they're absolutely fine it's just a sound drops out.
I'm contemplating moving to vmix which I would rather not do given the learning curve that's going to be required so if anybody has any ideas as to why OBS does this and better so how to fix this that'll be massively massively appreciated I have not attached a log file because I'm not on my desk at this time I'm not too sure what the log file will bring it on this particular occasion given the error and their failure is sporadic and not a routine pattern and it's between different computers..
Many thanks,
Lu
Fix the ATEM sample-rate mis-match. 44.1 > 48k Make sure the latest driver is installed, not sure if it needs to be compatible with 29.1.3?
McAfee is more than likely slowing everything down or worse & if you have any network issues, ditch the wi-fi.
15:18:37.050: OBS 29.1.3 (64-bit, windows)
15:18:37.050: ---------------------------------
15:18:37.072: ---------------------------------
15:18:37.072: audio settings reset:
15:18:37.072: samples per sec: 48000
15:18:37.072: speakers: 2
15:18:37.072: max buffering: 960 milliseconds
15:18:37.072: buffering type: dynamically increasing
15:18:38.642: [win-wasapi: 'Desktop Audio'] update settings:
15:18:38.642: device id: default
15:18:38.642: use device timing: 1
15:18:38.643: [Loaded global audio device]: 'Desktop Audio'
15:18:38.848: WASAPI: Device 'Speakers (USB Audio Device)' [48000 Hz] initialized
15:18:39.058: [DShow Device: 'ATEM-SSK'] settings updated:
15:18:39.058: video device: Blackmagic Design
15:18:39.058: video path: \\?\usb#vid_1edb&pid_be55&mi_04#6&16047b98&0&0004#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
15:18:39.058: resolution: 1920x1080
15:18:39.058: flip: 0
15:18:39.058: fps: 25.00 (interval: 400000)
15:18:39.058: format: MJPEG
15:18:39.058: buffering: disabled
15:18:39.058: hardware decode: disabled
15:18:39.541: using video device audio: no
15:18:39.541: audio device: Microphone (Blackmagic Design)
15:18:39.541: sample rate: 44100
15:18:39.541: channels: 2
15:18:39.541: audio type: Capture
Hey Rockbottom, so do I change those settings in the Atem or in OBS. Which would you recommend?
Thanks for the reply
I don't own a mini but I suspect that the audio settings can be adjusted. Also check Windows Sound Control Panel (drill into the device & check the Advanced tab) & any other device that you are sending the audio to. All should be @ 48k.
PostMon Oct 28, 2024 9:50 am
I do the streaming for a small church in Montana; I use the ATEM Mini, and OBS, both with the latest updates. I have had this same problem, that is, the stream sent to Facebook has worked well since 2021, but in the last year or so, I have had the sound just drop out: OBS shows no signal in the "VU Meter", yet, ATEM shows signal. I have the latest updates for OBS & the ATEM Mini, I have restarted the ATEM: no change; I try to "Stop Streaming" and "EXIT" but OBS will not shut down, unless I end it in Task Manager, restarting OBS does not work; I have to shut down the PC and restart EVERYTHING...... then it may work for the remainder of the service, but yesterday, it dropped audio again, 4 minutes after restarting everything. ARRRGGGGGG! This is unacceptable in a production environment! Please help!!!! (using 1 year old HP Pavilion Laptop, up to date Windows 11, ATEM Mini, and OBS - all up to date. Thanks)
I'm having the same problem. I'm planning to do some device bypass troubleshooting this week to see if it's the cables, ATEM Mini, USB-C... The last time it happened, the logs didn't seem to provide any indication as to why:
10:02:55.848: warning: EOI missing, emulating
10:03:08.376: warning: mjpeg_decode_dc: bad vlc: 0:0 (0000028BD0C39F88)
10:03:08.376: error: error dc
10:03:08.376: error: error y=133 x=91
10:03:10.872: warning: mjpeg_decode_dc: bad vlc: 0:0 (0000028BD0C39F88)
10:03:10.872: error: error dc
10:03:10.872: error: error y=134 x=2
10:03:25.863: warning: mjpeg_decode_dc: bad vlc: 0:0 (0000028BD0C39F88)
10:03:25.863: error: error dc
10:03:25.863: error: error y=133 x=98
10:03:26.376: warning: mjpeg_decode_dc: bad vlc: 0:0 (0000028BD0C39F88)
10:03:26.376: error: error dc
10:03:26.376: error: error y=133 x=61
10:03:31.464: warning: EOI missing, emulating
10:03:31.496: warning: EOI missing, emulating
10:03:54.376: warning: mjpeg_decode_dc: bad vlc: 0:0 (0000028BD0C39F88)
10:03:54.376: error: error dc
10:03:54.376: error: error y=133 x=68
10:04:25.511: warning: EOI missing, emulating
10:04:25.527: warning: EOI missing, emulating
10:04:35.350: [rtmp stream: 'simple_stream'] User stopped the stream
In the above logs, we noticed the audio had dropped out at 10:04:20 or so.
Were you able to find out what was causing your issue?
Hi,
Ultimately I sacked off the Atem and use a Xensys USB mixer as my input source. Mine is a 1024 but this is the next model up I think ****************40nNoqN with even more addons. Far more stable! HTH
Search Amazon for
"Behringer Premium 12-Input 2/2-Bus Mixer with XENYX Mic Preamps and Compressors" , £166 currently. Stupid I cant offer you a link in any way!!!​
Last year or so? Seems you reported this issue already in July 2021 ("this has worked very well, but, now, without warning or reason, the audio just dropsv - OBS indicates that the audio is simply GONE.")
Sounds like exactly the same issue those days... not a fresh one.
For professional use in churches i always prefer to use a prof. audio interface from the churches mixing board going by XLR (and, if needed, doing DI in case of hum) down to the interface which then interconnects to the computer by USB. Differnt USB than that of the Atem mixer. So two different devices OBS captures from, one for video, one for sound. If something happens with the Atem (for instance if forced to be rebooted mid the streaming), the people still hear the sound of the congregation and don't get lost. The video steps in and returns a couple of seconds later then.
Well. There is the nasty thing with delay between sound and video then. But. In most cases the video is late, so audio could be delayed (allowing the video device capture to catch up) to get it lipsync again. All audio devices should belong to 48k samplerate (strong recommendation!).
Thanks, Konsolenritter. I will consider that; the audio coming into the ATEM is from a low-z balanced (XLR) from the church board, so, I could use that, digitize that & usb - it into the PC, then set delay in the OBS for that appearance.
