OBS creates a Global PC Incoming Sound delay
PvtPJ
Hey all,
i need help cause i'm not able to fix my problem even tho i tried all I can (at least what i know)
Let me explain my weird problem.
I use OBS as my recording Software (I do not Stream!)
I use OBS to monitor all my virtual sounds to my Headset.
What does that mean?
My Game sound will be send to "G276HL (NVIDIA High Definition Audio)" (<- my Monitor)
My Discord Sound will be send to "Realtek Digital Output"
I Send my voice normally via my Mic "Microfone (USB Condenser Microphone)"
As you may know I cannot hear any Sound aslong OBS isn't running (sending all incoming to my virtual sounds)
and using the output monitoring OBS option.
Now comes the part where my problem is starting:
My Voice / Gamesound and cam are always synced (video and mic-audio)
But my Discord sound (or Teamspeak) will get delay at some point and on Top my whole PC Audio will be delayed aswell as
far as Stoping a Youtube Vod will result in still hearing sound for 1 to 2 seconds or while cuting a vod i can press start and stop and hear the sound 1sec later.
The Problem is immediately fixed after closing and reopening OBS.
Let's say i record a Game with my mates at the start i can without any problems hear them in realtime but as longer we play together the more delay i get.
This problem also exists if i DO NOT START RECORDING.
My Hardware Spec:
i9-9900kf
32GGB DDR4 3200
RTX2080Ti
M.2 Samsung 970pro
Watercolled and running all time under 60°C
I hope anyone could share exp or help me on this problem.
Greetings PJ
