0. Stick with the Ethernet streaming.
1. The Hardware-accelerated GPU scheduling ("HAGS") feature in Windows is currently known to cause performance and capture issues with OBS, games and overlay tools. It's an experimental feature and we recommend disabling it via
these instructions.
2. In Windows, we recommend that "Game Mode" be enabled. Game Mode can be enabled via the Windows "Settings" app, under Gaming > Game Mode.
3. OBS is not running as Administrator. This can lead to OBS not being able to Game Capture certain games. If you are not running into issues, you can ignore this.
4. Use the TwitchTest app from
https://r1ch.net/projects/twitchtest to find the best server.
5. Your log contains streaming sessions with dropped frames. This can only be caused by a failure in your internet connection or your networking hardware.
It is not caused by OBS. The quick fix is to enable dynamic bitrate. Settings > Advanced > Network > check box for Dynamically change bitrate... [Apply] > [OK]. Do that before you start streaming. If still having issues, follow the troubleshooting steps at:
Dropped Frames and General Connection Issues.
If still having issues, post 1 new log.
