For no reason at all my captures have started to stutter causing audio delay with my captured game audio. (using elgato hd60S+) 2 weeks ago it was fine but now its a problem.
Ive tried lowering resolution, adn changing them back lowering frame rate, using best encoder, using auto config tool, making sure my audio sources were the same, trying sync offset, re installing obs, priority is on highbut none of those worked. the duration of the stutters are inconsistent but it still happens eventually.pls help
Current log files: https://obsproject.com/logs/foYhKZx0QSPPV7GA
