Question / Help OBS Audio Clipping and No Audio from Mic in Stream and Recording
Money-T4GN
Hi Folks,
I am facing audio problems with OBS Studio that I use to Livestream and Record (Not at the same time) my games.
The Problem - When streaming for long hours (More than an hour) the audio (all of a sudden) starts clipping and at the same time my mic goes off (the Mic bar fiddles while talking but I can't hear myself speaking anymore in stream whereas I am actually speaking).
Evidence Video link - https://youtu.be/Dk65xLZg0QM (Start from 1:48:00 to find the issue occurrence)
I'm using 2 AudioSources. One for Desktop Sounds and other one for Mic. I play Intros so that's the reason of not using the defaults. Plus default audio is on 48KHz instead of 44.1 KHz with Stereo channel (Clipping starts instantly on Mono so not using that)
I desperately need help on this or any guidance. I can post log file if required
Can you post the exact moment that clipping occurs, and maybe the phrase that is said then? At 1:48:00 there is no clipping.
(FYI - at the very beginning of that audio there is already slight audio clipping of your mic: you should lower the sensitivity.)
