Hi!
Is it the OBS-ASIO plug-in that is the reson for that I´m not being able to monitor the processed stream using my Tascam US-4x4HR DAW interface?
When using it with standard driver only in a 2-channel mode the return audio is working but as soon as I install the OSB-ASIO plug-in the monitor stops working.
I have seen that there is some limitation on output-audio, I asume that also headphones connected to the interface is to classify as output-audio?
