OBS and Creative SB0880 Audio problem
tonycstech
Windows 10 x64 latest from Microsoft website.
OBS version current
SB0880 driver current
Problem description: EVERY TIME i open OBS studio, audio for microphone FP (front panel via cable connected to the SB0880 to go to the front panel of the PC) left channel is messed up and right channel is normal.
What fixes the problem: Opening (Moo0 Audio Recorder) immediately fixes the channels but it also screws up the input level setting it to 100% in the audio control panel instead of 60% as i set.
This fix is temporary. After reboot, it comes back so i have to run Moo0 audio recorder every time i want to record anything with a microphone.
I suspect that: WINDOWS has some old APIs that Moo0 accesses (because its old software) and triggering upper API levels to respond.
Maybe OBS can run on old APIs as well ?
This is incredibly annoying because half the time i dont even realize there is a problem until recording is done. I see output and i think all is well but its not.
