My problem is this: I can set an audio device other than a VB Audio Cable/Cable A/Cable B as my Advanced Monitoring Device, and it works (the other end of the virtual cable is connected to Zoom). I can output audio from a source other than OBS to one of the VB Cables, and it works (I'm using a Firefox plugin in this case).
What doesn't work is OBS, after my last update, using one of the VB Cables as either its Advanced Monitoring Device or set up through the Audio Monitor plugin.
Also, I have Voicemeeter Potato X64 installed; I can set one of its built-in virtual cables as the OBS Advance Monitoring Device, and that works.
Reinstalling the VB Cables did not help. Wondering if anyone has had a similar experience.
Log file
Log file
