Question / Help no sound with audio 8 dj
LUC030
Hey guys,
I have a problem to capture the sound of my audio 8 dj soundcard. I want to record&stream from my dj equipment.
The soundcard is shown in the OBS studio but there is no sound at all. But when I check the sound preferences in mac, there is a signal coming in.
Does anyone have the same problem?
Note: I have a mac book pro mid 2012
valterrier
Hey guys! I'm having the exact same problem except for I've Macbook pro mid 2014.
I've looked through dozens of discussions but couldn't find any adequate answer from OBS or NI staff. Please help! :)
DJJustinLuger
Similar problem here running an Ecler Evo 5 and time code in Traktor. The Ecler has an Audio 8 equivalent inside and Is connected via firewire/thunderbolt to my laptop.
TheFreedomist
I too am having this exact problem, and it's doing my swede in! I have a MacBook Pro (mid 2012) connected via USB to a DJM-850 with inbuilt Traktor capability, and when I'm mixing with timecode vinyl (switches at the tops of channels 1 and 4 set to USB) OBS picks up the whiny tone from the timecode aswell as the track that's being played. This is when I've chosen the mixer as the source for the audio input capture. When I'm mixing normal vinyl (switches at the tops of the channels set to Phono) it comes through completely fine, and I imagine it would do with CDJs aswell.
I've now got my old Audio 8 DJ out from before I got this mixer, connected it to my laptop via USB and then connected the master phono out on the mixer to the line input on Channel C (5/6) and there is no light from the levels on it unless I turn it up quite loud (I think I may have to tinker with the phono gain on it but I can't open the damn settings tool!), and OBS still doesn't register anything when the Audio 8 is chosen on the audio input capture.
All I have seen in my internet browsing is that it's highly likely that we might have to download a rather expensive app called Loopback which can route the audio from all sorts of things to/through eachother on your computer. It also seems like this is a uniquely Apple problem, which is another kick in the teeth after they removed the line in capability from MacBooks aswell. Dicks.
I have downloaded the free trial of Loopback to see if I can get it to work without paying for it first, and will keep testing and looking and see if there are any cheaper options, and hope that someone a bit more knowledgable chips in here aswell!
TheFreedomist
I've now realised I probably shouldn't be connecting the phono out to a line in so have now got the master phono output on the mixer going into the phono inputs on Channel A (1/2) and have fiddled with the phono gain settings so that the lights on 1/2 now light up with the signal, however OBS still doesn't register any sound. Back to the old drawing board!
TheFreedomist
Right, so I've now installed the free trial of Loopback and after some simple tinkering OBS now registers the Audio 8 being routed through the application which is available to choose as a source for audio input capture. It worked straight away and I am quite impressed, however I will keep on searching before biting the bullet and spending $120(!!!) on it.
TheFreedomist
May have spoken too soon, there is now a fairly loud hiss/buzz on the signal that could be a grounding issue or just the soundcard being fucked/old or just not very good for this sort of thing, I'm not entirely sure. The 20 min free trial has now ended so can't test anymore. It may involve getting a phono preamp/line converter involved in the mix and paying for the app aswell but will try to avoid that.
TheFreedomist
I'm not sure it iShowU is what is needed for this, I can't understand how it might work with Traktor and OBS in sync and can't be arsed with any more tinkering as it's quite late. I've appear to have gotten rid of the hiss by simply turning down the gain on the audio input capture on OBS and turning up the gains on the mixer channels to compensate, but I cannot be sure until I test it again with a virtual audio router like Loopback. Looks like I'm going to have to bite the bullet but will keep an eye out for other alternatives for a bit longer.
